1978 - 1996 Big Bronco
radiator
Old Mar 19, 2009 | 03:03 PM
Cdy1's Avatar
Cdy1
radiator
im getting a new radiator... mines shot, my question is will Radiator, 1992-94 460
fit my 95 with out problems. have 351w e4od..
Old Mar 19, 2009 | 03:11 PM
greystreak92's Avatar
greystreak92
You may need to sort out the mounting hardware and fan shroud (if you run a shroud) since you are dealing with a radiator for a 460 rather than your 351. The 460 is a big block and the 351 is a smallblock.
Old Mar 19, 2009 | 03:17 PM
Cdy1's Avatar
Cdy1
other then the mounts that i didnt check cuz its raining today and a bit cold but the sizes are the same i just dont want to buy it and it not fit =/
Old Mar 19, 2009 | 04:26 PM
Cdy1's Avatar
Cdy1
and.. are they fixable(old radiators) mines liakin bad out of the end where its crimped with the plastic
Old Mar 19, 2009 | 05:34 PM
greystreak92
Yeah, the plastic tank units are notorious for that. The problem is fixing a leak between the core and the tank on these units is that the cost usually exceeds the replacement cost so it's just not worth the effort to fix it over replacing it.
The cross-members in the engine bay should be the same as in other F-series truck so I don't honestly believe you would have to worry about it fitting... the mounting be still be the chief concern.
Old Mar 19, 2009 | 06:22 PM
Cdy1's Avatar
Cdy1
ok, thanx for the info =]
Old Mar 20, 2009 | 06:48 AM
Red Ford Truck's Avatar
Red Ford Truck
Talking Buy yourself a Griffin Rad and be done with it.
All welded aluminum and factory fit, about the same price as a premium OEM style but without the plastic tanks.
JMHO of course.
Rick.
rickdavis81
Jul 7, 2014 10:03 AM
Rick_Fury
Feb 7, 2012 10:12 AM
joe f350
13
Dec 10, 2010 10:28 PM
CJM8515
Jul 26, 2010 06:29 PM
rayroth
Dec 12, 2002 01:43 AM
