Fast Idle Problems
Old Aug 20, 2006 | 01:41 PM
STEVET1316's Avatar
STEVET1316
Fast Idle Problems
hello all
i am having idle issues with my 99 Expedition
it is an XLT with the 4.6L and the motor will
spuratically idle (when in neutral) up to 1500 rpm
900 rpm when i gear
does not do it all the time though
i have to date changed the following
IAC motor - 4 times
TPS once
O2 sensors
cleaned injectors
pulled top of the throttle body off and cleaned all of the carbon out
I have just put a ned Jet Chip in it along with a Jet
Power Flow Mass Air sensor on it
and a new Magnaflow muffler
everything i have done will not correct the idle problem
when i change the IAC motor it straigntens everything out for about 2-3 weeks then it starts all back over again
does anybody have a clue what may be causing this
rgds Steve 8/20
Old Aug 21, 2006 | 05:43 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 21, 2006 | 06:58 PM
FTE Herman's Avatar
FTE Herman
Welcome Steve! I'm sure you have checked but it sure soulds like an intermittent vacuum leak to me. If it's not they typical PCV elbow, it could be a leak around where you put that new MAF in.
dmb10505
1983 - 2012 Ranger & B-Series
Aug 20, 2010 08:19 AM
muddydawg
Nov 4, 2009 04:01 PM
fords and kenworths
Dec 3, 2007 09:44 AM
jcstratt
1997 - 2003 F150
Jan 31, 2006 11:28 PM
wrpittman2
Jul 27, 2004 04:25 PM
