Flywheel Problem
Old Mar 19, 2009 | 12:48 PM
Asylum's Avatar
Asylum
Flywheel Problem
On the flywheel there is a counterweight welded, I marked the flywheel and torque converter in the tranny where they should line up together. My problem is that I haven't marked where the flywheel should be positioned on the crankshaft of the block. The six holes can be lined up in any order. Does it matter where the counterweight should be positioned on the block?
Old Mar 19, 2009 | 09:56 PM
DasCheckers's Avatar
DasCheckers
The six holes cannot line up any way.
They only line up one way.
If you can't see it first then you have to put ALL 6 bolts in to find out which way it goes.
Don't forget your pilot bearing!
Old Mar 19, 2009 | 10:45 PM
White 97 xlt's Avatar
White 97 xlt
Originally Posted by dascheckers
the six holes cannot line up any way.
If you can't see it first then you have to put all 6 bolts in to find out which way it goes.
Bingo!!!!!!!!!!!!
Old Mar 20, 2009 | 02:49 PM
Asylum's Avatar
Asylum
Cool, thanks guys. I just got scared the other day when looking at it, seemed like the 6 holes were identically spaced apart.
Old Mar 20, 2009 | 02:55 PM
DasCheckers
Nope, they're uneven. So no worries man!
crazy96863
May 10, 2013 06:19 AM
Xclimation
Jul 22, 2011 10:54 AM
junkyarddog82
Feb 12, 2008 09:53 PM
brownt
Nov 5, 2002 05:11 PM
