battery cables
Old Mar 18, 2009 | 09:05 PM
Polkster's Avatar
Polkster
battery cables
positive cable passenger side clamp tore up when trying to disconnect, need to replace clamp.
Is there a clamp only that will hold the 2 positive cables or do i need to buy whole harness?
Where is the best price for the harness?
Or where can i get clamp only?
Thanks.
Old Mar 18, 2009 | 09:41 PM
megawatt00's Avatar
megawatt00
NAPA or a marine supply store will have what you need. You can just replace the clamp.
Old Mar 18, 2009 | 10:21 PM
adamzelazowski's Avatar
adamzelazowski
I have same problem with my one van some sugestion the postive cable cost 250 on dealer.I think on old model this looks beter two battery on both side.This is bad conect two cable thru one batery
Old Mar 19, 2009 | 12:21 AM
twags6's Avatar
twags6
Check out connector G on this page. Its either crimped or soldered on. McMaster-Carr
Old Mar 19, 2009 | 12:56 AM
adamzelazowski
Thank you good website , some sugestion about chose conector
Old Mar 19, 2009 | 01:10 AM
adamzelazowski
I think 69735K71 this conector been perfect but Im not sure how much power style d awg 1 or 2 or 4
Old Mar 19, 2009 | 06:42 AM
megawatt00's Avatar
megawatt00
Can you buy from McMaster as an individule? Years ago I tried and they were for commercial account holders only.
Old Mar 19, 2009 | 07:44 AM
riverrat41's Avatar
riverrat41
Jim...Yes you can.We buy a ton of stuff here at my work but I order stuff as well for personal use.
Old Mar 19, 2009 | 07:46 AM
megawatt00's Avatar
megawatt00
Thanks Barry. I worked for Titleist and at that time they wouldn't sell to me privately.
Old Mar 19, 2009 | 07:49 AM
riverrat41's Avatar
riverrat41
You may have to set up an account with a password.Kinda a PITA but once it is set up you are good.
Old Mar 19, 2009 | 07:50 AM
Ford79's Avatar
Ford79
You can check here too Battery Connector Terminals | Battery Cable Terminal Clamp - Remy Battery
Old Mar 19, 2009 | 07:51 AM
megawatt00's Avatar
megawatt00
Awesome Barry Thanks!! Reps to you my friend!
Old Mar 19, 2009 | 10:02 AM
twags6's Avatar
twags6
Yup. This is where I got the SS tubing for my intank mods.
