frame rust
Old Oct 7, 1999 | 08:35 AM
alan_3's Avatar
alan_3
frame rust
Have a 1988 F-150 just had built and installed a new 351w.
Now I find the frame above the right radius arm bracket is pitted through.
Two questions;
1, has anyone had any experience with repairing frame rust ?
2, I am told that this is not a "cast" frame but rails of bent "laminated" stock, that the inner layer of the lamination is of a less noble grade steel ie.. once pitting reaches the inner layer the frame is trash. Any truth to this ?
Old Oct 13, 1999 | 02:26 PM
matt_1's Avatar
matt_1
frame rust
on an 88 you have a bent extruded steel frame. Once fitting gets to bad, the frame is virtually tash... but if its an area small enough, "say less than 6" x 4" I have had success with cutting out the bad section, "without cutting into the top or bottom, just the web of the frame." with a plasma cutter, and welding in a new piece of steel. Be careful though not to get it too haot when your welding. I have also heard of people cutting out whole sections of the frame and welding in a new piece, but I would avoid this, because I wouldn't trust it.
Old Nov 4, 1999 | 07:52 PM
Mark H.
Guest
Posts: n/a
frame rust
fabieber
Mar 30, 2016 10:42 PM
thunderbolt427
Feb 23, 2016 09:05 PM
F250_
51
Jun 25, 2015 09:02 AM
Gotanoldtruck
Mar 19, 2014 05:22 PM
Joe_D
Jan 12, 2009 01:53 PM
