A/C not working
Old Mar 18, 2009 | 08:20 PM
dstone8368's Avatar
dstone8368
A/C not working
I need some help on this one. My 97 ranger 4.0 supercab the a/c only works in the max a/c position. in normal a/c mode i get only hot air but if i go to the vacumn heater control valve in the engine compartment and manually close it the truck will start cooling. what operates this valve?
Old Mar 18, 2009 | 09:23 PM
Rockledge's Avatar
Rockledge
Unfortunately, it sounds like you have blend door issue. Check out:
Free Ford Blend Door Fix
https://www.ford-trucks.com/forums/7...lend-door.html
