upper tie rod replacement....
Old Mar 18, 2009 | 08:09 PM
swaybar's Avatar
swaybar
today i did my rear diff fluid with motorcraft gear oil i got from the dealer. tight as a drum with no leaks and i'm happy, good piece of mind. vent on the axle seemed clogged, (just a reminder for all ya)
well, while on my creeper i coasted up to the front while checking things out. as i went to grab my upper tie rod (the one with the adjusting sleeve) to pull myself forward i noticed it was "very" loose. both sides were gone. so off to the the store and $140 later i've got both left and right rods and the adjusting sleeve.
the exchange seems pretty staight forward but is there anythng else i should know other than (out with the old-in with the new) ??? thanks.
Old Mar 18, 2009 | 08:16 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
make sure you measure end to end, before you take it apart
Old Mar 18, 2009 | 08:17 PM
nissandoc's Avatar
nissandoc
The obvious: alignment
Lube all the other fittings
And since you are in Mass. soak it for a long time before you start. I always see PB blaster and WD40 mentioned here but never ZEP. They have a product called Zep Preserve that makes the other stuff look like pi$$ water. I'll see if I can find a link somewhere.
Old Mar 18, 2009 | 08:43 PM
nissandoc's Avatar
nissandoc
Try this Zep Superior Solutions ::: Product Catalog?:
You may have to find a dealer to get it
You guys would be AMAZED at how much better this stuff is over PB and WD.
Old Mar 18, 2009 | 08:53 PM
swaybar's Avatar
swaybar
thanks darrell, i did the ball joints back in the fall so one side of the rod's been off recently and shouldn't be a problem. the other i'll just have to see but i'll keep the "zep" in mind.
Old Mar 18, 2009 | 09:46 PM
PowerstrokeJunkie
And you would be amazed at how much better Schaeffer's Penetro is than THAT
Old Mar 18, 2009 | 09:52 PM
big poppa's Avatar
big poppa
Good deal on the rear fluid change, did mine not to long ago, piece of mind it is. Good catch on the UTRE.
'94IDITurbo7.3
Jul 6, 2012 08:57 AM
ttttmaxx
Jul 22, 2010 11:08 AM
Justin's Green Truck
Feb 12, 2010 05:32 PM
Rev.Josh
20
Jan 27, 2009 09:47 AM
Happy Hillbilly
Sep 8, 2006 11:05 PM
