painting
Old Oct 21, 2000 | 12:07 PM
mrfixit's Avatar
mrfixit
painting
hey
i want to paint my truck but i am not sure what to use to take the old panit off? do u use a sand blaster or a grinder? and for putting the new stuff on should i just use spray paint or should i use a airgun???
thanks
Old Oct 22, 2000 | 09:56 AM
oleblue70's Avatar
oleblue70
painting
Well,
neither!
You never mentioned if you have acsess to a good air compressor or not.
Sand blasting sheet metal can be a big mistake.It can cause distorsion,and a mess.
Grinding might be a idea.Well not really grinding,Eastwood Company has a nice paint striping wheel.
As for painting the truck.Use a good siphon feed gun or a hvlp gravitiy.Spraying it from rattle cans will be a waist of all the work you did getting ready for paint.'nuff said.
...blue
1970 f250 4x4
Old Nov 3, 2000 | 05:20 PM
buzzard's Avatar
buzzard
painting
Why are you stripping the truck in the first place? Unless there is a tremendous build-up of existing paint, you don't have to strip it all off. All you really need to do is scuff sand the old paint and fix any imperfections with filler then prime and paint.
By no means should you use spray paint from a can. You will be so disappointed in the results and durability will really suffer. As previously recommended get a decent gun and compressor and use good quality professional grade paint...it's not that expensive in the long run.
Old Nov 3, 2000 | 10:04 PM
oleblue70's Avatar
oleblue70
painting
buzzard is right.
sand whole truck w/ 80grit with a DA,then fix body work go after all 80g areas with 180,then shoot full coats of urethane filler primer,sand with 320,then when all body work is final,shoot another good wet coat of urethane filler primer reduced 25% and wet sand with 400 then 600.
It's alot of work but that formula i just gave will have ZERO sand scratches and will be perfect for shooting paint.
I recommend having someone else shoot it for ya but at the same time practice makes perfect.
But practice can be expensive to you be the judge when it's time to paint.
...blue
1970 f250 4x4
oleblue70's Avatar
oleblue70
painting
[font size="1" color="#FF0000"]LAST EDITED ON 03-Nov-00 AT 11:08 PM (EST)[/font][p].
Old Nov 9, 2000 | 07:40 PM
oleblue70's Avatar
oleblue70
painting
BIGskinny
24
Jun 2, 2011 03:09 PM
lmd91343
Mar 30, 2010 06:59 AM
marioc956
Paint & Bodywork
Feb 4, 2007 11:02 AM
mfd18
Paint & Bodywork
Nov 29, 2006 03:53 PM
pkweed
Paint & Bodywork
Sep 23, 2004 07:04 PM
