painting undercarriage
Old Jan 8, 2007 | 11:32 AM
marioc956's Avatar
marioc956
I want to know if I can use enamel paint to paint all the undercarriage any advice on this or should I use a different type of paint
Old Jan 15, 2007 | 03:51 PM
ubereal2's Avatar
ubereal2
Enamle would work on the under carraige. But if you are wanting a tougher/stronger paint. Go with emron.
Bob
Old Feb 2, 2007 | 06:53 PM
WALFORD'S 56's Avatar
WALFORD'S 56
Enamel is fine for the frame.Imron is even better-but expensive and stinky_ha ha!!I like to use CHASSIS-SAVER brand for frame and rust areas,and on the current project-the whole truck.
Old Feb 2, 2007 | 11:21 PM
fastfordmobile's Avatar
fastfordmobile
Im doing mine right now. Using iron oxcide primer, then a couple of coats of rustolium semi black enamel.............
Old Feb 4, 2007 | 10:29 AM
JohnT's Avatar
JohnT
Smile
I've just been using black spray paint on the undercarriages of my trucks. It's inexpensive and easy to work with. It does need to be touched up every couple of years, though.
Old Feb 4, 2007 | 11:02 AM
Indy_Gearhead71's Avatar
Indy_Gearhead71
If you're building a show truck, even if you're not, powder coating is flat out the most durable and chip/scratch resistant way to go. An enamel will work just fine and Imron is some pretty durable stuff, just make sure you have a brand new mask and get ready to throw it away when you're done. lol
Geeeyejo
Sep 22, 2014 10:07 PM
publiuss
Appearance & Dress-Up
Jul 12, 2012 01:08 PM
skirk55
Delaware Chapter
Aug 29, 2009 03:09 PM
conman3300
Jun 9, 2008 10:44 AM
F0rdF0rever
Apr 19, 2004 07:50 PM
