Black Smoke
Old Mar 17, 2009 | 09:10 PM
jwilkinson's Avatar
jwilkinson
Black Smoke
I have an 07 F-250 6.0 powerstroke. 136,000 Miles and never been in the shop, Never had any problems at all. But today I noticed it smoking alot ( Black Smoke ). It was due for an oil change anyway. So I got the fuel filters and Air filter chaged, but its still smoking. Now I noticed its Idling rough. Also when you turn on the key, the fuel filter makes noise alot longer than it did...Thanks in advance for your help...
Old Mar 17, 2009 | 09:42 PM
william_04_x's Avatar
william_04_x
does it smoke all the time, or only when you apply throttle? you might have a bad injector which can lead to serious problems if it's not addressed quickly..
Old Mar 17, 2009 | 09:44 PM
jwilkinson's Avatar
jwilkinson
It smokes more than usual at idle. But when you apply throttle, it really smokes alot....
Old Mar 17, 2009 | 09:54 PM
william_04_x
most likely a leaking injector...it's really in your best interest to get it checked out ASAP...having it towed to a shop would be wise if you can't do it yourself..
pull your dipstick and check to see if you can smell fuel..i had a couple leak bad enough that almost 2 gallons of fuel ended up in the crankcase oil..
Old Mar 17, 2009 | 09:57 PM
jwilkinson's Avatar
jwilkinson
Im gonna have it checked first thing in the AM. Ill also check the dipstick too..Thanks for your help...
