1978 - 1996 Big Bronco
1995 front hubs
Old Mar 17, 2009 | 04:20 PM
Bronco bob 369's Avatar
Bronco bob 369
1995 front hubs
I need to disassemble the front hub on my 1995 Bronco to check and grease bearing . My repair manual shows the wrong hub assembly . after removing the cap I don't seem to have a lock ring to hold the hub assembly in. I need to know how to get it out. It's a full size with a manual hub.
Old Mar 18, 2009 | 03:50 PM
Cdy1's Avatar
Cdy1
i have a 95, auto hubs i assume. yes they do have the ring they are harder to see and get out with the auto hubs but theyre there. i replaced mine with manuals... hate the auto ones =P
Old Mar 18, 2009 | 03:55 PM
Kemicalburns's Avatar
Kemicalburns
which manual are you using? the haynes has good instructions.
Old Mar 18, 2009 | 04:22 PM
McLeod's Avatar
McLeod
Both auto and manual have the same outer lock ring.
Here is a picture of both:
auto hubs
manual hubs
Old Mar 18, 2009 | 08:38 PM
Bronco bob 369
Thank You all , I could not see the ring at first . Is there a easy way to get it out ? It sure seemed hard but I finally got it out.
Old Mar 18, 2009 | 09:07 PM
McLeod's Avatar
McLeod
I took an old test light with a sharp point and bent the tip ever so slightly.
Slides right under snapring.
Old Mar 18, 2009 | 09:18 PM
Bronco bob 369
OK I'll try that thanks.
Old Mar 19, 2009 | 08:00 AM
helirich's Avatar
helirich
After you get it out, file/grind a 45 degree on both ends. it will make your life easier next time you take it apart. (It gives you an edge to get a pic under) Make sure the 45 is with the point to the center. (if you do it the other way, it will be harder to get the pic under.)
Old Mar 19, 2009 | 11:47 AM
Kemicalburns
or got to harbor frieght and buy some snap ring pliers.
Old Mar 19, 2009 | 12:20 PM
McLeod's Avatar
McLeod
What kind of snap ring pliers would work on the outer ring?
Old Mar 22, 2009 | 09:41 PM
rudedogii's Avatar
rudedogii
What you need is an O-ring pick or just pick one up next time at the Dentist.
Old Mar 24, 2009 | 12:22 AM
dwg999's Avatar
dwg999
I have a '95 also and replaced my auto hubs with a manual set from Warn.
I also filed 45 degree angles on the snap rings to simplify removal (it does help). I ended up using a small screw driver to remove it the first couple of times that I had it apart.
What I did to make removal even easier was to drill a small hole in the hub so I can insert a small nail to force the ring out (it is really easy now).
Old Mar 24, 2009 | 08:02 AM
helirich's Avatar
helirich
I can see how that would make it easy, but it could leak grease because thats inside the o-ring.
Old Jun 11, 2009 | 02:15 PM
dwg999's Avatar
dwg999
Silicon Sealed the Hole
To prevent grease from leaking, each time I remove the ring I reseal the hole with a small dab of silicon.
It works quite well.
I realize this is an old thread but I thought I would add this in case anyone else needs it in the future.
