Modular V10 (6.8l)
Thin oil.
Old Mar 17, 2009 | 04:08 PM
Stumpalump's Avatar
Stumpalump
Thin oil.
It dosn't seem right that Ford recomends such thin oil. I talked to a Mobil engineer a year ago and he recomended 15w50 year round for any flat tappet cam engine. Im sure this V10 is a roller motor so it uses thinner oil but why so thin. I have 55 k miles and it runs good but think I would like to run the same 15w50 synthetic I put in everthing else.
What are you running and why?
Old Mar 17, 2009 | 04:14 PM
mwsF250's Avatar
mwsF250
Why so thin? Much better oils and better machining processes allow much tighter bearing clearances. This provides longer engine life, faster oiling at start up, and less friction. It really is a good thing.
If the oil is too thick, it will be difficult to force it into those tiny clearances, meaning no oil film in the bearing, especially at start up. No oil film means those bearing clearances will get a lot bigger, really fast.
As an engineer, I have to advise following recommendations unless you have a special situation or special knowledge.
Old Mar 17, 2009 | 06:33 PM
dkf's Avatar
dkf
Do a search and find a pic of a torn down modular head casting. The cam journals ride on machined aluminum bosses with NO bearings. A thinner oil is best to get up there and lubricate the journals. Many other possitives for thinner oil. I run 10w-30 in my 35+ YO 302 with no problems. I don't run gear oil in my engines.
Old Mar 18, 2009 | 07:49 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
15w50 is WAY too thick.
Over the years here at FTE, we've had a few people drop in both here in the V10 forum, and the 4.6/5.4 forum complaining about top-end noises.
Guess what they did? Ran a thick oil for years and then wondered why the cam journals were hogged out, or the cam lobes were scored, or some other top-end issue.
Cold-start is the worst time for engines, especially overhead-cam engines. The thin oil gets up there quicker.
Old Mar 18, 2009 | 09:55 PM
V10_Cougar's Avatar
V10_Cougar
I'm with dkf. I have been running Castrol Syntec 10w-30 for years with no problems. I also run it in the cougar
Old Mar 19, 2009 | 08:03 AM
dkf's Avatar
dkf
I run 10w-30 in 302 in my 74' F-100 where as many run thicker oil in that engine. My V10 get 5w-20 and thats it.
Old Mar 19, 2009 | 11:17 AM
V10_Cougar's Avatar
V10_Cougar
Do you know the difference between 10winter-30 and 5winter-20
Old Mar 19, 2009 | 04:12 PM
Stumpalump's Avatar
Stumpalump
10w30 flows like a straight weight 10 when it's real cold and thickening agents in it make it flow like a 30 weight when it's real hot. They basically dump it in a funnel and count the seconds it takes to flow out. 10 seconds=10 weight 30 seconds is 30 weight. The w in 10W30 stands for winter but it's basically 10 weight oil with crap in it to slow the flow when it's hot. Ever wonder why racers use straight weight? Because all those additives are not oil and not much of a lubricant either. They break down in time and turn to vapor. Thats why your oil stays full for a long time then all of a sudden your mysteriously 1/2 quart low. The additives turned to vapor and went thou your PCV. That tells you it's time to change it no matter what the miles are.
Old Mar 19, 2009 | 04:54 PM
BareBones's Avatar
BareBones
That's the explanation I always understood relative to oil weight designations, but I got a real eye opener this winter. I left a quart of 5W20 dino oil and one of Mobil 1 synthetic oil out in -20 temperatures overnight, then poured them the next morning. Hugh, hugh difference! Somehow or other the ratings definitions of oil must have changed over the years....
Old Mar 19, 2009 | 05:01 PM
BareBones's Avatar
BareBones
Don't worry, I'm only in my 60's. I'll eventually learn how to spell/type "huge"...
Monsta's Avatar
Monsta
Sit. Stay.
Multi-viscosity oil DOES NOT THICKEN when hot. It resists thinning. Your X weight (insert first number here ) will never thicken to become XX (insert second number here ).
A 5W-20 weight oil is a 5W base stock that will resist thinning as much as a 20 weight would at 100°C. Think of it as a percentage. Not that it thins 20% but more if a 20 weight oil thins "X amount" at 100°C then the 5-weight base stock will only thin as much as well.
Only gravy thickens when hot.
Barebones, the difference you noticed between the two oils is due to the molecular makeup. The dino's molecules are not uniform hence the thickening. Synthetic oil have molecules that are all uniform and do not "bunch up" like that.
Old Mar 19, 2009 | 06:38 PM
BareBones's Avatar
BareBones
Thanks, Monsta. Whatever the explanation its clear that synthetic is the better oil in Northern winters.....
The real question is though, if one oil flows so much faster than another, how can they both meet the same standard?!
Old Mar 19, 2009 | 07:18 PM
Monsta's Avatar
Monsta
Sit. Stay.
Standards are created at a particular temperature.
Old Mar 20, 2009 | 02:09 PM
69cj's Avatar
69cj
I use 10w30 synthetic in my 69 428 cobra jet with no problems at all.
Old Mar 22, 2009 | 12:00 AM
Saleenguy's Avatar
Saleenguy
I always use 5w30 Mobil 1 synthetic oil in my modular motor fords.
I have never had anything but great results from Mobil ! oil.
It also gives me a little extra protection on a scorching hot summer day, pulling a 9,500 pound trailer up a mountain pass.
