fuel drain valve
Old Mar 17, 2009 | 02:45 PM
jleal_21's Avatar
jleal_21
fuel drain valve
where is the fuel drain valve located? water in fuel light is on.
Old Mar 17, 2009 | 02:54 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
jleal_21, its under the frame rail Driverside. You should see the filter housing clear enough, thats the HFCM (Horizontal Fuel Control Module). Depending on what year you have the plug can be easily removed and drained. Just make sure you have a bucket under it to catch the contaminated fuel that comes out. You may also want to upgrade to a Knurled thumb wheel plug (if you have the older 8MM hex head plug that is flush mounted in the HFCM). It's about $17 dollars at your local dealer...or maybe even cheaper at a local International store. You may have to drain it a few times depending on how bad the filter is contaminated.
Old Mar 17, 2009 | 03:00 PM
jleal_21's Avatar
jleal_21
whoops its an 05 f250
Old Mar 18, 2009 | 07:10 AM
MoyockPowerstroke
Yeah, mine too...just follow as described above. If you have any questions just ask away, I'll subscribe to your thread to keep up.
Old Mar 18, 2009 | 07:29 AM
bismic's Avatar
bismic
Slight correction - the allen wrench size is a 6mm.
jleal_21 - The tech folder has what you need (and much, much more).
