92 ford f 150 trans problem
Old Mar 17, 2009 | 02:07 PM
bokoaa's Avatar
bokoaa
The truck has 95.000 miles the trans is slow going in forward and reverse
otherwise works great. any ideas how to remedy the problem?
Old Mar 18, 2009 | 10:57 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Moved from 2011 F100 forum.
Welcome and thanks for joining us at FTE!
Old Mar 18, 2009 | 11:27 AM
Lazy K's Avatar
Lazy K
When was your last fluid and filter change?
Old Mar 18, 2009 | 12:07 PM
bokoaa's Avatar
bokoaa
That has all been done. as I said the trans works great except for going
into forward and reverse, it has about a 4 second delay.
Old Mar 18, 2009 | 03:34 PM
Lazy K's Avatar
Lazy K
Try posting this on the tramsmissions page (scroll down a bit from here), there are a couple of good transmission experts visit there.
My thought was a dirty filter but you have ruled that out. Another possibility is a badly fitting filter however I assume it was doing it before the new filter. It could also be a stuck drain back valve allowing fluid to flow back from the converter when the truck has been sitting. You could do a search of the transmission page for more info on that.
Hope this helps.
Bestays Pom
1983 - 2012 Ranger & B-Series
Jun 14, 2012 08:28 AM
don77
Jan 2, 2009 05:11 PM
photomac
Nov 30, 2006 06:11 PM
katdon2001
Mar 13, 2006 09:47 AM
