Intermittent Tachometer Cured!
Old Mar 17, 2009 | 11:56 AM
mudgepondexpress's Avatar
mudgepondexpress
20+ years of a tachometer that works when it wants to was cured this weekend with 1 hour of work. I can't take credit for figuring it out so here is to Eddiec1564! You are THE MAN!
Originally Posted by Eddiec1564
Sounds like the problem I had on my tach. What I found was inside on the circut pc board of the Tach was some old yellow colored glue that turned brown and started conducting current. I cleaned off the browning yellow glue and resoldered some cold joints and that took care of that problem. Since then I fixed about 5 tachs for the same thing. Funny thing is Mitsubishi TV's of the late 80's/ early 90's had the same yellow glue that browns up and causes all types of problems...
I will add, my glue was still quite plyable (sp?). It was in 4 locations on the board (which I left attached to the tach) all around the tall green inductors (I think). I used a small curved pick to get the glue off the board and away from the legs of the component. I didn't clean the board afterwards, nor did I have any cold solder joints, just reinstalled and it has yet to fail.
Man I love a working tach! My dash is back to normal!!!!!
Kenny
Old Mar 17, 2009 | 12:41 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
That is funny, RCA's had the same thing, same time frame!
Right on!
I wonder how many customers got raped for replacements!
-Enjoy
fh : )_~
Old Mar 17, 2009 | 02:43 PM
Eddiec1564's Avatar
Eddiec1564
Good to hear you got it fixed!! I am still seeing that yellow/bown glue in some newer electronics again. Don't they ever learn....
Festus ,rember those bad tuner connections of RCA chassis too?
Old Mar 17, 2009 | 09:03 PM
Festus Hagen
Methanoholic
That's how I impressed my wifes folks the first time we met, pulled the back off, gave the connections a good wiggle and was instantly a genius!
Should of seen the look on their faces while I was pulling their expensive console apart!
We still laugh about that!
-Enjoy
fh : )_~
Eddiec1564
Mar 14, 2025 03:25 PM
Eddiec1564
15
Aug 15, 2016 07:40 PM
Eddiec1564
Oct 3, 2014 05:20 PM
Eddiec1564
15
Dec 7, 2013 11:02 AM
