stop rust
Old Jan 22, 2001 | 10:48 AM
oldfordsidestep's Avatar
oldfordsidestep
stop rust
I know that there are chemicals out there that change the chemical compisition of rust so that is stops growing there. But I am not sure what the best type is. Are there any special ways to put it on so that it works the best.
And...
My truck's wheel wells were tared a long long time ago. Would it be worth it for me to do it again? What kind of tar would I use? And where would I get it from?
I also want to paint my frame now that I have my bed off. what is the best way to remove the rust from the frame. I was thinking to use a D.A. with 60 or 80 grit on it but I thought I would get your advice first. Is there a better harder type of enamle paint that I can use on the frame that will better repel water and keep rust away??
While I am painting the frame in the rear I would Also like to paint the U joint and drive line. The only problem is that it has some stuff that I can't get off of it. It is kind of like a hard dirt/oil/tar/30year-bake-time mixture. I'm sure you know how to get this off. I was thinking about useing one of those striping chem. But you tell me! I don't want to ruin a seal or anything.
Thanks for having the endurence to read that whole thing!!
-Tyler
Old Jan 22, 2001 | 11:53 AM
oz9609's Avatar
oz9609
stop rust
Tyler, the Eastwood Co. has frame restoration and paint material. Check them out.
Old Jan 22, 2001 | 04:40 PM
karljay's Avatar
karljay
stop rust
Eastwood has enamal frame paint, but you can get epoxy paint at most good paint stores. I like the Por15 for the frame, and use a wire brush on a hand grinder to prep the frame.
Por15 works best on rust but Dupli-color's rust fix and Sem's Rust Mort work good too. Rust Mort is great for body panels as it is very thin.
As for cleaning, the final clean should be with denatured alcohol and either paint stripper of wire brush before that.
Old Jan 25, 2001 | 09:37 PM
a1fendermender's Avatar
a1fendermender
stop rust
khakushia
21
Jan 26, 2012 06:04 PM
stevenn1
Dec 7, 2006 12:06 AM
hillbillyk
Paint & Bodywork
Aug 27, 2003 04:14 AM
Screamin T/A
Paint & Bodywork
Mar 17, 2003 06:48 PM
oldfordsidestep
24
Jan 25, 2001 02:08 AM
