95 F150 with DJM 3/5 drop question
Old 03-17-2009, 12:47 AM
john410312's Avatar
john410312
john410312 is offline
I posted this in the suspension forum already but no one replied.
After installing the DJM 3/5 drop kit on my 95, my measurements are all wonky.
I lost the BEFORE measurements but the after measurements are as follows..
Left Front 16 1/4" Right Front 15 7/8"
Left Rear 15 1/2" Right Rear 16"
Would I be in the market for new rear springs because of the half inch difference in the rear measurements?
Right side measurements are within 1/8 inch but from this pic...
...it still looks a lot lower on the rear. I haven't got left sides to post but the 3/4 inch difference is noticable.
Would full fuel tanks cause a 1/2 difference in height between LR and RR?
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
Old 03-17-2009, 11:13 AM
truckfanactic's Avatar
truckfanactic
truckfanactic is offline
I am sure that you took the truck to an alignment shop after you installed the lowering kit. If not then that may be your problem.
Old 03-17-2009, 03:31 PM
Jason Lewis's Avatar
Jason Lewis
Jason Lewis is offline
After i installed my Lightning Springs i used DJM Drop Shackels in the rear and used the first hole the truck is almost level when i drive the rear sinks back a little. When i fill both tanks the rear sinks about an 1/2 Inch more.
One more thing my stock leaf springs i had on i had the bed sag on the left side, after installing the Lightning leafts i still have the bed on the left side.
Old 03-17-2009, 09:20 PM
john410312's Avatar
john410312
Thanks Jason. I was wondering if maybe 36 gals of gas would cause the rear to sag a bit more. That's almost 300 lbs.
I flipped my rear axle. It dropped 5.5 inches. The dream beams didn't get the full 3 inches. Did you install L springs in the front too? If so, how much did it bring it down? I'm thinking I should drop the front another 1 to 2 just to make it look right (in my mind). Then try to figure out the tire size for the front when I put the L wheels on.
Old 03-17-2009, 09:27 PM
Jason Lewis
yea front L coils it dropped 1" inch , the rear dropped 3" inches using tires size 275/60r17
john410312
Vehicles for Sale
08-01-2016 05:17 PM
sddesigns
New Jersey Chapter
04-20-2010 06:58 PM
sddesigns
New Jersey Chapter
04-14-2010 01:55 PM
rat49f6
04-04-2009 09:22 AM
428HIGHBOY
15
02-17-2009 07:02 PM
Quick Reply: 95 F150 with DJM 3/5 drop question
