Injector Nightmare!
Old Mar 16, 2009 | 06:57 PM
jkidd_39's Avatar
jkidd_39
Originally Posted by ron's power stroke
do you by chance have the gray CPS in your truck???
Black one.. Grey one is hanging out in the glovebox.
Old Mar 16, 2009 | 06:59 PM
ron's power stroke's Avatar
ron's power stroke
your down to IDM or a new set of injectors...got a friend with a truck you could swipe the IDM from to test???
Old Mar 16, 2009 | 07:01 PM
jkidd_39's Avatar
jkidd_39
Plan on doing the idm swap this week. This sucks
Old Mar 16, 2009 | 07:03 PM
F350-6's Avatar
F350-6
My guess is injectors. Too many stories about rebuilds not running right. Have you considered doing the labor yourself? We could walk you through the process. Sounds like 6 more from Ryan should have you up and running.
If you're concerned about Ryan's injector, swap it with one in another cylinder and see what kind of difference that makes.
ron's power stroke
i hear ya..when it rains it poors..good luck to ya...
Old Mar 16, 2009 | 07:10 PM
jkidd_39's Avatar
jkidd_39
hmmm.. How difficult is an injector swap? I'm not the most mechanical kid.. I did do that tymar intake and exhaust but I think this is a little more involved...
Old Mar 16, 2009 | 07:17 PM
ron's power stroke
if you can change spark plugs..then your good to go...just take your time and read your steps..we are always here to help if you need it..
Old Mar 16, 2009 | 07:18 PM
tdpower's Avatar
tdpower
What tests are you doing to confirm a bad injector?
Old Mar 16, 2009 | 07:20 PM
F350-6's Avatar
F350-6
Not really that hard. There are more steps involved, but if you can work a ratchet, and have access to a few rags and a torque wrench, you can do this. After all it's just removing a bunch of bolts, pulling the injector, and putting the bolts back in.
There's a few more steps involved, but that's basically all you're doing. Don't let it intimidate you.
Old Mar 16, 2009 | 07:22 PM
ron's power stroke
read up a little about it here..beans sells Ryans injectors..
http://www.beansdieselperformance.co...torinstall.pdf
Old Mar 16, 2009 | 08:02 PM
jkidd_39's Avatar
jkidd_39
One the CCT all injectors on the left bank are reading low. They don't buzz as loud on the buzz test.
He's got a box where he can turn off certain injectors and with the left bank off it runs great. Right bank off and they run like crap.
The numbers are not low enough to cause a CCT Fault. But it certainly sounds bad.
Old Mar 16, 2009 | 08:15 PM
tdpower's Avatar
tdpower
Buzz tests only test the injector solenoid. I would guess that you have a bad solenoid (which you can replace separately) or you have a wiring issue on that wire to the injector or idm. Could even be in the idm I guess. Did you get the same test results with other idm's?
Old Mar 16, 2009 | 08:18 PM
  #28
F350-6's Avatar
F350-6
The truck runs better with all the injectors off, or just one of them? This may be out in left field, but you might consider disconnecting batteries for 5 minutes before running the next buzz test to make sure a bad solenoid isn't putting the IDM into safe mode.
Have you tried ohming the injectors on that bank to see if one of them is reading different than the others? I've see an ohm reading difference of 0.6 shut down the entire bank.
Old Mar 16, 2009 | 08:19 PM
  #29
jkidd_39's Avatar
jkidd_39
Buzz tests only test the injector solenoid. I would guess that you have a bad solenoid (which you can replace separtely) or you have a wiring issue on that wire to the injector. Could even be in the idm I guess. Did you get the same test results with other idm's?
I have been fighting with the idm for a while. I got one coming tommorrow. If that one is bad then I'm pulling an idm off my other truck
Old Mar 16, 2009 | 09:15 PM
  #30
tdpower's Avatar
tdpower
I would ohm out I to C on that bank. Make a comparison to the other side for a good reference.
G - G - I - I - C - I - I - G - G
One out of range would indicate a bad solenoid. Test these at the valve cover or at the injector itself with a pigtail or old harness cut and plugged in.
