Sponsored by: Auxito
01 F-150 question
Old Mar 16, 2009 | 05:23 PM
jspaulding13's Avatar
jspaulding13
01 F-150 question
So, I broke the clutch bleeder screw and the end of the metal line that connects it to the slave cylinder off today on my 01f-150. I was wondering if there was any way to replace the short section of line without removing the tranny. There is a small hole on the bottom of the bell housing that you can uncover by removing a rubber cover. Is there any way to remove and reinstall the line from there or am I screwed(no pun intended). Thanks ahead of time for any help.
Old Mar 16, 2009 | 05:57 PM
steve(ill)'s Avatar
steve(ill)
im not sure exactly what you got. if the line is sticking out an inch from the case, you can get a ferrel type fitting at NAPA and slide over it and connect a new tube up to the firewall. if the line is broken inside the bell housing, i think you might be screwed? if its inside, can you slide deep well socket over the tube nut?
