Squeaky Brakes
Old Mar 16, 2009 | 02:51 PM
Frdtrtnv8's Avatar
Frdtrtnv8
Squeaky Brakes
I have a 2008 f-150 fx4 x-cab with only 12k. I recently took it in for inspection with 11k on it, and it passed, no issues. All of the sudden by brakes are squeaky. They only squeak when I am hardly moving and I push the brake pedal in or when I am not moving and I have the truck in drive. They do not squeak when I push the brake pedal in when the truck is in neutral. Anyone ever hear of this or know what could be wrong?
Old Mar 16, 2009 | 08:17 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
how often do you drive the truck?
when is the last time you washed your brake rotors/calipers?
do the brakes squeak when you are actively using the brakes...or just when lightly on them?
Old Mar 16, 2009 | 09:10 PM
irishammer's Avatar
irishammer
If your brakes squeak when you are not moving that is VERY strange!!!! Don't understand how they could do that...
Old Mar 17, 2009 | 06:00 AM
Frdtrtnv8's Avatar
Frdtrtnv8
brakes
Only when i am lightly on them, maybe there is dirt in there. But now i am hearing a clunk in the rearend when i put the truck in drive or reverse and hit the gas. I will be going to the dealership.
Old Mar 17, 2009 | 10:58 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
3 things typically cause squealing brakes.
1. dirty rotors/calipers
2. light rust. if it's been raining/snowing, the rotors develop a light rust film each night. the first few times you use them, the rust will get knocked off. but until it does, you get a slight squeal
3. brake wear indicator
Old Mar 17, 2009 | 10:16 PM
irishammer's Avatar
irishammer
He says he gets the squealing even if he is not moving! I want to know what the cause was when he finds out....I have a feeling it is not the brakes.
Strokt350d
6.2L V8
Jul 2, 2014 06:53 AM
woodtrucker
Oct 3, 2013 08:36 AM
mikecox1
Sep 19, 2008 12:49 PM
mizzitch
Aug 2, 2007 03:02 PM
tsargent
1997 - 2003 F150
Jul 24, 2003 02:04 PM
