newbee here
Old Mar 16, 2009 | 01:16 PM
bigshotsho93's Avatar
bigshotsho93
newbee here
so i just bought an 04 expedition eddie bauer, loaded every option but navigation. and its got a few minor things not functioning. i need some advise on where to start the diagnosing process. i already hit the fuse block in the right kick panel. no blown fuses there. on to the problems
the heated/cooled seats don't work.
the reverse sensors don't function, nothing happens when i get close to something.
the rear wiper doesn't move with the motor, i can hear the motor moving but the wiper doesn't move, i can move it by hand but its not connecting with the motor.
other than those little things its a great truck! i think its the best thing iv ever bought. i look forward to learning alot from this forum and will be posting here alot from now on.
Old Mar 16, 2009 | 02:05 PM
rconnjr's Avatar
rconnjr
If it were me, for the seats I would look at the switch or a pulled or broken wire under the seat maybe. Where is the switch? maybe something got spilled on it before you bought it. The reverse sensors, again I would look under the rear bumper and trace the wires and look for any broken wires. When I bought my 97 the running board light wires were broken in many places. No problems with my 03 except for the crazy mirrors.
The rear wiper shaft may be stripped. Try to remove the wiper arm and look at the shaft. I think you can access the motor through the inside cover if you need to remove it.
Good luck
Old Mar 16, 2009 | 05:50 PM
ford12508's Avatar
ford12508
If you just bought it did you get a 30 or 90 day warranty or something of the sort? If you did go right to the dealer and tell them that they sold you a car with some bum features and you would like them fixed. If they refuse, then TELL THEM they sold you a car with some bum features and they WILL be fixed.
Old Mar 16, 2009 | 06:08 PM
bigshotsho93
these are things i need to fix on my own. the expedition was bought as is.
Old Mar 16, 2009 | 08:43 PM
alloro's Avatar
alloro
Make sure your reverse lights are working. The sensors only turn on when you're in reverse. So if the lights aren't working then the backups sensors will not either.
Remove the cap at the bottom of the rear wiper arm. Observe if the nut turns when the wiper switch is on. If it does then the splines inside the wiper arm could be stripped, or the nut could just be loose. Usually you can just replace the wiper arm if the splines are stripped and the problem will be solved.
Old Mar 17, 2009 | 07:38 AM
alwaysfords41's Avatar
alwaysfords41
Both seats don't work? What happens when you hit the switches - do they light up or does nothing happen? It is unusual if both are out since they are fused and switched independantly.
Old Mar 18, 2009 | 08:05 AM
bigshotsho93
neither the passenger or driver heated/cooled seats work. the "dial" 1-5 lights up with the parking/head lamps, but the hot/cold buttons do not light up when pressed. owners manual says the hot will light up red and the cold will light up blue when pressed nothing happens.
Old Mar 18, 2009 | 08:17 AM
ltrager's Avatar
ltrager
There is a TSB for the seats not working. I just had my 04 Navi front drivers seat redone under extended Warranty.
Old Mar 18, 2009 | 04:21 PM
ltrager's Avatar
ltrager
Heated and ac seats not working. The lights in the switches - JustAnswer
Here is the TSB info
Old Mar 18, 2009 | 08:22 PM
bigshotsho93
Originally Posted by ltrager
thats alot of things that could be wrong. i was hoping for an easier fix for that. but thanks for the link. i dont even know where to start with that. might need some help from someone that deals with this kind of thing more often.
anything about the rear back up sensors?
Old Mar 19, 2009 | 07:58 PM
briank's Avatar
briank
Do you have the owners manual? If not, they can be turned on and off by using the information center or what ever they call it. Where you reset mileage and status.
Old Mar 20, 2009 | 08:07 AM
bigshotsho93
yes and i already tried that. there is no option for the rear sensors.. i followed the instructions perfectly and all the other options were there but not the reverse sensors. is it a possibility that my eddie bauer expedition didnt come with the rear bumper with reverse sensors and the previous owner added the bumper with them? maybe got rear ended or something. i thought all EB expeditions came with the back up sensors?
Old Mar 20, 2009 | 10:03 AM
alwaysfords41
On the reverse sensor issue, what does the message center say when you put the truck in reverse?
Old Mar 20, 2009 | 11:00 AM
c_hohensee's Avatar
c_hohensee
Do you have a switch on the dash for park assist? On the 03 explorer there is switch on the dash to turn it off, on that vehicle it is not controlled through the message center.
Old Mar 20, 2009 | 05:51 PM
alwaysfords41
not on a switch, it is through the message center.
