what the location?
Old Mar 16, 2009 | 01:14 PM
cowmilker08's Avatar
cowmilker08
Question what the location?
where is the fuel screen at that is near the fpr?
I'm gonna change the fuel filter tomorrow and figured I'd clean that screen
since I've read how much of a difference it can make.
Also any tips for changing the filter? I've never done it before.
Old Mar 16, 2009 | 01:22 PM
phillips91's Avatar
phillips91
when you pull the filter out look towards the drivers side of the fuel bowl and there will be a hole there. look inside the hole and youll see the screen. as far as changing the filter, just make sure you push the new filter in reallllllly slowly. if you dont, youll shoot fuel out all over the place.
Old Mar 16, 2009 | 03:29 PM
BlueMule's Avatar
BlueMule
The fuel bowl should be empty when you change the filter, otherwise when you remove and install the new filter the sludge and crap on the bottom of the bowl mixes with your fuel and gets on the "clean" side of the filter.
Old Mar 16, 2009 | 03:36 PM
cowmilker08
how do you get the fuel bowl empty?
Old Mar 16, 2009 | 03:55 PM
BlueMule's Avatar
BlueMule
There's a yellow plastic lever on the right front of the bowl, turn it 90* toward the passenger fender and it opens the drain valve. You might have to remove the lid to break the vacuum to get it to drain.
Old Mar 16, 2009 | 03:59 PM
cowmilker08
i was wonderingwhat that lever was for.
where does it drain to?
do i need to bleed the air out of the system after i change it?
If i do then how do i go about doing that?
Old Mar 16, 2009 | 07:40 PM
Welk49's Avatar
Welk49
mine has a hose that runs down and drains under truck. You don't have to do anything to bleed the air out, it will work itself out
Old Mar 16, 2009 | 09:57 PM
MissIndependent's Avatar
MissIndependent
lol, mine doesn't have a hose...and it drains just a bit to the left or right of wherever i put the catch pan! more or less in the vicinity of the oil drain bolt is where it comes out though
i put clean fuel in the bowl as per previous advice here. it went everywhere when i put the new filter in. it was lots of fun :P
also i've decided i like napa filters better than autozone filters. in general, if it costs more, my truck likes it better
Old Mar 16, 2009 | 10:06 PM
cowmilker08
Yeah i've noticed that too with some other things.
Old Mar 17, 2009 | 07:13 AM
Neal 97 250's Avatar
Neal 97 250
Open the drain valve
Remove the Filter bowl lid.
once fuel is drained out remove filter.
Replace with new filter.
Replace lid.
Close Drain valve.
Start truck.
If the drain does not want to drain after the lid is removed.
Replace the lid and close the valve.
Start the truck.
Carefully open drain valve. (stay out of moving pulleys)
Verify fuel pressure is forcing fuel out the drain valve.
Close the valve.
Shut off truck.
Go back to step 1 of this post and perform those steps. The bowl should drain now.
Old Mar 17, 2009 | 07:26 AM
phillips91's Avatar
phillips91
i never thought about that. on my fuel filter box it said to install slowly so you dont spill fuel everywhere, but it does make more sense to just drain it first.
