Sponsored by: Real Truck
OEM Steering Stabilizer Replacement
Old Mar 16, 2009 | 09:28 AM
jlalanas's Avatar
jlalanas
Wanted to get some suggestions on the best OEM stabilizer replacement. I have an 08 f250 psd 4x4 and just want to upgrade the stock unit. I'm running the stock tires and don't plan on going much larger on tires and primarily use the truck for highway use.
I've seen many dual kits and single kits that don't use the stock mounting, so wanted to get some feedback on what others are using and where they've purchased.
Thanks.
Old Mar 16, 2009 | 10:10 AM
WildWildWest's Avatar
WildWildWest
I went with the Rough Country stabilizer. It was reasonably priced and mounts in the stock location. It's a much beefier unit and made a world of difference over the worn out OEM stabilizer that was on the truck since new. I changed out the OEM stabilizer at about 56,000 miles and I could move it in and out easily by hand. If Bilstein made an OE replacement for our trucks, I'd have bought that.
Old Mar 16, 2009 | 10:11 AM
dchamberlain's Avatar
dchamberlain
I put the Rancho stabilizer on from shockwarehouse.com. It seems like a good unit, but I haven't driven it much since I put it on.
Old Mar 16, 2009 | 10:12 AM
Carl Lassiter's Avatar
Carl Lassiter
Stocker is good only for the trash can. Icon makes a good dual
Old Mar 16, 2009 | 10:45 AM
sarnott140's Avatar
sarnott140
Thumbs up
I second that
Old Mar 16, 2009 | 10:47 AM
loudford's Avatar
loudford
I went with the rancho from shockwarehouse as well. Mounts to existing and there was a noticiable difference from the original. I wish bilstein would make one as well, I'd have bought that one.
Old Mar 16, 2009 | 11:04 AM
saltamontes's Avatar
saltamontes
i have the fox steering damper.
very high build quality, but it comes charged w/ nitrogen at 200 lbs.
you prob will have to drop that down some (i set mine at 50 and that works perfect).
brian42's Avatar
brian42
Veteran: Navy
I replaced mine with a Pro Comp (stock bracket). I'm running stock 265s so I don't need anything too beefy. I spent about 30 bucks and it works great. I off-road so I'll eventually misjudge my clearance and end up banging it again. And when it gets beat up enough, I'll spend another 30 bucks for another one.
Just my .02
Old Mar 16, 2009 | 11:23 AM
jlalanas's Avatar
jlalanas
Thanks guys...not sure if the 08 has the same mounting as prior years. Mine doesn't sit parallel to the axel. It's tucked up on an angle attaching to the upper steering linkage??? I think this is the reason why i'm not finding many oem replacement ones. any thoughts??
Old Mar 16, 2009 | 12:03 PM
dchamberlain
I see two at shock warehouse. A Monroe and the Rancho. Note that while the photo on the Rancho page shows the dual setup, that item is NOT the dual setup. With stock suspension and tires, you probably don't need a dual setup anyway.
http://www.shockwarehouse.com/site/p...ing-Stabilizer
Old Mar 16, 2009 | 12:06 PM
sarnott140's Avatar
sarnott140
Yes, but you don't need one that sits in the same location as the stocker, you can leave it there or throw it out. As far as I know all the dual stabalizers run parallel with the axle and will work well with your truck
Old Mar 16, 2009 | 12:14 PM
jlalanas's Avatar
jlalanas
thanks, i appreciate everyone's input.
Old Mar 16, 2009 | 05:14 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
I just installed the Icon dual bracket and bilstein 5100s. World of difference and an extremely easy install. I was starting to get a lot of feedback through my steering wheel and the steering wheel never returned to center on it's own. I always had to turn it back to center. With the dual Bilstein setup, I'm getting no feedback through my steering wheel and the steering wheel easily returns to center. I can't believe I waited this long to upgrade. Night and day difference.
Old Mar 16, 2009 | 06:14 PM
Fordfanatic4life's Avatar
Fordfanatic4life
dont bother with going to dual if ur sticknig to stock sized tires..
it would be overkill..
a single aftermarket (quality unit) will calm down tires up to about 35"s.. after that large u should look into duals..
Old Mar 16, 2009 | 06:33 PM
Skylaneman's Avatar
Skylaneman
I bent my stock unit about 4 years ago when I dropped a wheel in a small irrigation ditch. Took it off and never noticed a difference. Drives like any other truck I've ever had. I have 285/75's.
lwk362393
Feb 3, 2021 09:10 PM
Amicus
Sep 6, 2016 02:05 PM
bulletpruf
Oct 29, 2012 08:43 PM
WIKD
Feb 24, 2012 11:59 AM
Biggziff
Jun 13, 2007 07:09 AM
