Left hand thread lugs??
Old Mar 16, 2009 | 05:39 AM
boggerted's Avatar
boggerted
Well, I thought I would share my experience with my 84 F250. I must have spent two hours trying to remove the drivers side rear wheel only to realize after taking it to a tire shop that its left hand threaded. All the other wheels on the truck are regular thread, and that one wheel has its own set of lugs. I dont see the practicality of this system, and if anyone was thinking of removing the rear wheels to be aware of this.
Old Mar 16, 2009 | 06:03 AM
dustybumpers's Avatar
dustybumpers
someone has changed your studs out for ones for a dodge. I am not aware of ever finding reverse lug nuts on a ford. if it dosn't bother you that way, leave it, if it does, pop them out, and put in the proper ones for a ford
Old Mar 16, 2009 | 08:21 AM
fellro86's Avatar
fellro86
They did put lefties on some, my dad's 84 has them on both front and rear wheels on the passenger side. The thinking was to keep the lugs from working loose... my 86 does not have them, so they didn't run with it very long.
Old Mar 16, 2009 | 08:29 AM
lew52's Avatar
lew52
I never heard that before....I knew the old dodges had left hand threads on one side...They were ussally stamped with a L on the end of the stud...
Old Mar 16, 2009 | 08:52 AM
fellro86's Avatar
fellro86
All of his pass side lugs have the L on them, and the rears are factory, as we have had it since it was new. The rotors have been changed though, but it retains the lefties. It also has the D50 up front. and a Dana in the rear.
Old Mar 16, 2009 | 09:40 AM
bashby's Avatar
bashby
My friends 83 f350 dually has lefties on one rear wheel
Old Mar 16, 2009 | 09:49 AM
dustybumpers
hmmm. never saw that before, good to know.
Old Mar 16, 2009 | 10:27 AM
Freaksh0w's Avatar
Freaksh0w
I remember the first old Dodge I encountered that was like this, lol. Why the hell did they do that? The passenger side was normal, and the driver's side was 'backwards'.
Old Mar 16, 2009 | 10:41 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The studs are the proper Ford parts, these: (8) DOTZ1119A .. Stud-LH / 9/16" -18 x 2 3/4.
Ford began doing this on trucks in 1932. These specific studs have been used since 1970.
Old Mar 16, 2009 | 01:02 PM
1 F150dude's Avatar
1 F150dude
I had two 70's era ford trucks (72 and 76)with the left and right hand lugs. Havent seen it on newer trucks though.
Old Mar 16, 2009 | 08:39 PM
kaotikedge_111100's Avatar
kaotikedge_111100
My 83' F240 4X4 has a semi-float dana 60 in the rear end and the drivers side is left hand threads. I found out the hard way also, after a 4ft breaker bar which I stood on, it got so tight that the lug went through the steel wheel.
I am taking that whole crappy axle out and putting in a D70 with normal threads.
Old Mar 16, 2009 | 10:42 PM
hydmech's Avatar
hydmech
My 81 f250 Had lefties on it as well. Had to do the brakes anyway. Put new rotors and drums on and now they all go the right way.
Old Mar 18, 2009 | 01:27 PM
460Brnc's Avatar
460Brnc
The Dana rear axle I got off of a 1984 F250 HD also had left hand threads on the driver's side. Makes for real fun when you get new tires and forget to tell the shop about the LH threads. Your first clue is when you hear the noise of an air impact wrench trying in vain to get the driver's side rear wheel off.
Old Mar 18, 2009 | 01:36 PM
tlk50's Avatar
tlk50
Dodge was famous for LH studs on drivers side and RH on passenger side! Seen a lot of snapped off studs on Dodge pickups back when.
Old Mar 18, 2009 | 01:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Don't change them to right hand threads, if they are left handed.
They are that way for a reason.
It's all to do with Centrifical Force and the GVWR of the vehicle.
The idea is the centrifical force of the trucks wheel going down the road forward will tighten up the lugs, or keep them tight with left handed on the left, and right handed on the right. If you change them to right handed on the left, it could loosen up and the wheel can fall off.
All large trucks have left handed lugs on the left for this reason as well.
The more weight the truck can hall, the more prevelent the reason becomes.
