Sponsored by: Real Truck
EGT probe
Old Mar 15, 2009 | 10:27 PM
mikelovfrod's Avatar
mikelovfrod
EGT probe
I have a 2007 6.0 and just purchased the bullydog pmt chip that includes an egt probe. I was curious about where to install my EGT probe. Pictures would be great! Also what temps are safe and unsafe to be at? Thanks!!
Old Mar 16, 2009 | 05:44 AM
Furian's Avatar
Furian
You Keep What You Kill
Subscribed! I have an EGT probe that came with my SCT Livewire and would like to know as well. I know that EGT's are more applicable to diesel engines than gas engines but I still want to install mine since it may help the SCT Livewire tune better.
Welcome to FTE!
Old Mar 16, 2009 | 02:36 PM
Beerstalker's Avatar
Beerstalker
The 6.0L forum has a bunch of threads on installing the EGT probe. I would recommend going down there and doing a search.
Most people install them near the rear of the driver side exhaust manifold.
Old Mar 16, 2009 | 08:46 PM
F350-6's Avatar
F350-6
Welcome to FTE. As stated, the common place is the rear side of the drivers exhaust manifold. Some probes come with brackets to be installed on the up-pipes (diesel only), but drilling and tapping the manifold is the most common install method. You want to see pre-turbo readings on your gauge, usually around 1200 deg F or less.
