E4OD Help!
Old Mar 15, 2009 | 10:02 PM
jeffsk7's Avatar
jeffsk7
E4OD Help!
My overdrive light falshed toaday but then stopped. The tranny was rebuilt with HD torque converter and overdrive and is also equipped with an tranny cooler and a knew MLPS only 6000 miles on it. The o/d flashed happened twice. The second time it happened was when I put it in reverse the tranny pooped into gear a littler harder than normal. I then turned the truck off and back on and there was no flashing. Let me know what you guys think. Also how do i test to see what code is comming up.
1993 f250 ext 4x4 125000 miles 7.3 idi
Old Mar 16, 2009 | 10:41 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The flashing light means an error code was stored. You can use a really cheap ($25) reader to get the codes, or use a paper clip and read the flashes on the light. There are instructions floating around the net on how to do that, I don't have a copy.
Without the code nobody knows what's wrong.
Old Mar 16, 2009 | 11:28 PM
javi2001's Avatar
javi2001
Try Ford Fuel Injection there are instructions to get codes very easy
