7.3 ip
Old Mar 15, 2009 | 09:13 PM
staffbuoy's Avatar
staffbuoy
7.3 ip
Had a guy put a used IP on now she gets fuel lock smokes like a train. Took her back to him he said the eng is gone nothing wrong with the pump he put on.Before I had the pump put on there was no power in her.wondering if the guy timed it right from what iam reading here thanks
Old Mar 15, 2009 | 09:17 PM
bad12jr's Avatar
bad12jr
What color is the smoke, does it smell like raw diesel or sooty, how many miles on the engine, turbo or N/A, do u still have a muffler?
Old Mar 16, 2009 | 10:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I wonder how much the IP fuel setting is cranked up?
When the engine is cold when first started do you have a rattle that goes away when the engine warms up?
Rattle should be more pronounced with a slight depression of the throttle.
The rattle should quite when the fast idle kicks off.
What is the power like with the new pump?
Any change the air filter needs changed?
What are you meaning by fuel lock?
Old Mar 16, 2009 | 11:02 PM
starmilt's Avatar
starmilt
Try running a compression test you will at least know more about the condition of your engine.
MrVerilog
New Member Introductions
Oct 29, 2014 06:05 AM
sjwelds
28
Apr 11, 2014 01:05 PM
Fordboy350
13
Apr 19, 2013 07:10 PM
Mikey Oldaker
Oct 4, 2012 01:13 AM
Bonanza35
Jul 7, 2012 09:58 PM
