ABS light flashing codes?
Old Mar 15, 2009 | 08:57 PM
zxwut?'s Avatar
zxwut?
I thought the ABS light would flash out a code if there is a problem with something or another. I can't find through search what the number of flashes mean. Can someone help quickly please? The truck was just ran sideways into a tree and we're trying to figure out what's wrong with everything. Thanks.
Rob
Edit: 97 F250 HD Powerstroke 4x4 btw
Old Mar 16, 2009 | 06:07 AM
Furian's Avatar
Furian
You Keep What You Kill
You may need to provide more information for the FTE members to assist you. How many times is the ABS warning light flashing? Can you drive the truck or is it too damaged? If you can drive the truck, then you may want to go to AutoZone and have them read the codes. Knowing the codes will greatly assist you in completing the repairs.
Old Mar 16, 2009 | 06:27 AM
F350-6's Avatar
F350-6
When the key is first turned on, the lamp will flash a code. 2 flashes pause 7 flashes means code 27, etc. Tell us what the code is and we'll see if we can help.
Old Mar 16, 2009 | 09:03 AM
zxwut?'s Avatar
zxwut?
Sorry, I didn't think about it last night. My parents don't have a whole bunch of money and this is my dad's only way to work so I was just really frustrated and kind of panicky. I am visiting and he let my 16 year old brother drive it and he was driving too fast on a dirt road apparently and slid off into the ditch into a couple of trees. Had to use 4 wheel drive just to get it on the road again. We thought we were going to have to use the tractor to get it out but it still ran so that worked out. It was drivable home but the bed is mangled and the cab is crushed on the left side. It actually ripped the 1/4 steel brackets holding the extra 50 gallon diesel tank in the bed in half. I had to use a grinder to get the left fender off. It ripped apart from the front and bottom seams of the bed and was only hanging on by the few rear spot welds but was so mangled that I couldn't get to them to cut them out so I just cut it in half. He's just thinking about getting another truck with a blown engine or something, and putting his engine/trans in it. This just sucks all around. Anyways, it flashes 15 times short and once long then 15 short then once long over and over. I checked to see if the brake lines were damaged and that everything was still connected but couldn't find anything wrong. Help please!
Old Mar 16, 2009 | 11:45 AM
Furian's Avatar
Furian
I could be wrong but it appears that it is Code PO1501 - VSS Out Of Self Test Range. I found this on this FTE forum:
https://www.ford-trucks.com/article/...sel_Codes.html
There are a few threads on VSS:
https://www.ford-trucks.com/forums/8...-abs-help.html
https://www.ford-trucks.com/forums/6...-blinking.html
Use the search feature by entering "VSS" and you find all of the threads.
Old Mar 16, 2009 | 12:10 PM
zxwut?'s Avatar
zxwut?
Thanks for the help. Probably just going to part out this thing.
Old Mar 18, 2009 | 07:32 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the 94.5-97 7.3L forum by owner's request.
Old Mar 19, 2009 | 07:18 AM
Neal 97 250's Avatar
Neal 97 250
Sorry to hear the bad news. have you made the decision to part it out yet?
Did it ruin the frame? Sounds like it took a big lick.
Anyway did you solve the code issue?
Good luck
tex1441
Electrical Systems/Wiring
May 21, 2023 07:58 AM
cat2000zrt
Feb 14, 2011 03:50 PM
jeremyibe
Aug 20, 2002 05:16 PM
stevieray
Sep 18, 2001 05:36 AM
