Battery Draining Problem
Old Mar 15, 2009 | 05:36 PM
Sparky83's Avatar
Sparky83
Question Battery Draining Problem
I need help tracing a problem... the battery in my truck keeps dieing and cant figure out why... the battery in my stang is 5 yrs old and can go 3 weeks (sometimes more) without needing started... the battery in my truck is BARELY a yr old.. and having problems with it... replaced it last yr cuz it kept dying.. and couldnt remember hold old it was.. just knew it was old.. and now it seems like the same problems are coming back again.. it was charged mid week last week... mom took it to church on sunday and said it cranked over with no problems at all then... but when i went to try and start it yesterday it was dead dead... it tried to turn the engine over twice (very slowly) and then started the "im dead" clicking... being only a yr old i shouldnt be having this problem...
Anyone know how i could trace to find out if somethings or whats drawing on the battery even when the trucks off that could be killing it so fast? I pulled the battery today and its sitting in the garage atm on a trickle charger... (2amp charge) gonna probably leave it there over night to see if i can really bring it back to life...
Old Mar 15, 2009 | 06:34 PM
rockin300's Avatar
rockin300
the fuel pump relay could be the problem my friends 91 f150's battery drained all the time and it had to do with the fuel pump
Old Mar 15, 2009 | 06:38 PM
Sparky83's Avatar
Sparky83
anyway to test and see if thats it without replacing it first?
Old Mar 15, 2009 | 06:40 PM
rockin300's Avatar
rockin300
im not sure he took it to the shop
Old Mar 15, 2009 | 10:01 PM
Franklin2's Avatar
Franklin2
You can hear the fuel pump running if that's the problem. Here's a way to test and find out what the drain is. Hook up a testlight like the diagram below, and then start pulling fuses. Make sure the domelight is off. Disconnect any added stuff like amplifiers that are going to the battery. If none of this makes the light go out, take all the wires off the alternator and see if the light goes out.
Old Mar 16, 2009 | 10:55 AM
donjamer's Avatar
donjamer
Shawn, before you get ripping things out to far, Have you checked to see if the alternator is charging??
Put a meter across the battery with the truck running.. If you are reading 12V or less then the alternator is not charging.. It should read around 14V if the alternator is working..
Next I would check and clean all the battery cables and grounds..
If that doesn't help then you need to look for a short as described above..
Old Mar 16, 2009 | 11:05 AM
donjamer's Avatar
donjamer
I just thought of another option..
My son had a 77 F250 that when it sat the break pedal would relax and turn on the brake lights.. He put a bungie cord to fix it till he did the brakes..
Have you ever looked at the truck at night to see if a light is on anywhere?
Old Mar 16, 2009 | 11:07 AM
BAJI26's Avatar
BAJI26
Maybe you can do the same here: https://www.ford-trucks.com/forums/8...ml#post7014971
Old Mar 16, 2009 | 05:01 PM
Sparky83's Avatar
Sparky83
test light lit dimly when i put the battery back in the truck.... and got 14.78v when it was running...
gonna see if i can find the cell checker thing in the garage and test the cells...
Old Mar 16, 2009 | 05:02 PM
Sparky83's Avatar
Sparky83
ohh and brake lights werent on don...
Old Mar 16, 2009 | 05:31 PM
Sparky83's Avatar
Sparky83
i just thought of something... i thought mom was the last to drive it on sunday... but i took it to get it inspected tuesday... so that means the battery died in only 4 days...
Old Mar 16, 2009 | 05:38 PM
Foxxy's Avatar
Foxxy
lil ms. innocent
ditto that
Old Mar 16, 2009 | 05:46 PM
BAJI26's Avatar
BAJI26
Look in post #8 of this thread there is a link and if you click on that link and read the thread it will help you track down the source of the current draw. If there's one!
Old Mar 18, 2009 | 06:15 PM
Sparky83's Avatar
Sparky83
apparently it was a draining problem after all... suggestion i got from one of my other sites i checked the battery cells individually (took me a couple days to find that cell checker of dads)... 4/6 cells came out "high fair" they were teetering on the line between good and fair... and the last 2 cells were "recharge" so theyre pretty much dead cells to me... this is apparently the root cause of my problem.. we had a couple days last week between tuesday when i last drove it and when i tried to drive it sat where temps got into the 20's and 30's... which as everyone knows when temps start to drop batterys charges drop as well... was killing off the charge enough apparently to make it worthless in starting the truck...
looks like its time for a new battery..
Old Mar 18, 2009 | 07:41 PM
donjamer's Avatar
donjamer
Good to see you got it figured out Shawn..
