need help, can DRW hub fit on a D50 FE?
just changed out my SRW rear axle on my F250 with a DRW V171C 4L10 axle, and new (repainted ) factory dually bed. now I need to figure out the FE, that way I can use 6 of the same wheels. I really can't afford the D60 solid axle conversion (preferred) I don't like the Arrowcraft adaptors, so, can the D60 FE hubs and offset junk fit onto the D50 and keep the same calipers, 4wd hubs, rotors etc...?? This way it is all OEM stuff and readily available at part centers. any info is gladly welcome I am certain that someone out there knows.
Thanks.
DB916gt
Thanks.
DB916gt
