Got a problem
Old Mar 15, 2009 | 04:26 PM
USMarine2001's Avatar
USMarine2001
Got a problem
Howdy all! I was looking over the forum and seems there is a lot of knowledge here. I was hoping someone would be so kind as to aid me with my problem. I have a 1976 F250 Super-Cab with a 360, and noticed my steering sucked one day. Got to looking it over and found that the steering coupling is absolutley shot. So I got a new one but can't seem to get at the old one enough to remove it. I have a pic if anyone can help. I have vise-grips on the shaft near the firewall and a couple of boxed ends on the nuts and bolts. I have been putting down quite a bit of torque but all I seem able to do is turn the wheel Help?
Shane
Old Mar 15, 2009 | 04:36 PM
79f150toy's Avatar
79f150toy
It may be easier to remove the steering column from the truck...unbolt from the steering box, remove the two cover bolts, romove the two bracket bolts, unplug the t/s switch, remove the dust boot from firewall and then pull the column out.... it may take a little longer to do this, but it may avoid the aggrevation...atleast you could hold it still with a vise....good luck...
