whats going on???
Old Mar 14, 2009 | 03:00 AM
ironhead86's Avatar
ironhead86
whats going on???
hey everyone. its seems of late when I take my truck for a drive and i go back and start it it just barely cranks over and if it doesnt fire up it just wont start at all. so I put a new battery in it thinking everything was fine and it did it again. the alternater is only a year old. I need to get an after market voltage gage for my truck the old one is stuck right in the center. do you think this could be a starter problem or something. thanks for any input. 75 f250 460ci
Old Mar 14, 2009 | 03:08 AM
Ranger76's Avatar
Ranger76
starter is probably getting hot or its worn out and dragging.
Old Mar 14, 2009 | 03:22 AM
Don S.'s Avatar
Don S.
Check battery to Frame ground and Motor to Frame grounds. For that matter check all your ground spots.
Old Mar 14, 2009 | 08:41 AM
hillbillyk's Avatar
hillbillyk
check your timing, if it is to far advanced when the motor is hot it will turn over slow.
Old Mar 14, 2009 | 12:30 PM
ironhead86's Avatar
ironhead86
I will check all the ground areas today as well as the starter itself. I did check the timing and it is good. thanks for the help. if the starter does need replaced, is the a good aftermarket one the you would recomend.
Old Mar 14, 2009 | 12:47 PM
Rockstone's Avatar
Rockstone
If you have headers on the truck, you might try some header wrap, or fab some kind of shield around the starter as well. Heat kills these things.
Old Mar 14, 2009 | 01:04 PM
VocaTexas's Avatar
VocaTexas
I only buy replacement starters, alternators, etc. from NAPA. I also buy the lifetime warranty when possible. I haven't paid for a new starter, alternator, or plug wires in years.
Old Mar 14, 2009 | 03:34 PM
ironhead86's Avatar
ironhead86
thanks. i just called my local NAPA store and they said they would check the battery and alternator in my truck. that should narrow my possibilities. thanks
Old Mar 14, 2009 | 03:36 PM
78workhorse's Avatar
78workhorse
Just my 2 cents but, I would spend the couple extra bucks and buy a brand new starter. I havent had good luck with reman starters. Even from Napa. The one I have now is a Remly I do believe. Made in China but what isnt anymore? Got tired of replacing the starter every couple months. The last one I got 3 weeks out of.
Old Mar 14, 2009 | 05:20 PM
Don S.'s Avatar
Don S.
Also another option, I recall some saying that there is a possble Gear reduction starter that will swap into the 460's. That really helps compaired with the direct drive starters.
I could be wrong on that so make sure to verify.
Old Mar 15, 2009 | 12:27 AM
ironhead86's Avatar
ironhead86
thank you don S and everyone. it was my starter. I am ordering a new one. thanks again. mark
Old Mar 15, 2009 | 05:04 PM
79f150toy's Avatar
79f150toy
If you are having probs cooking starters(due to excessive heat or timing issues), use a starter from a newer 460(early 90s I believe), with the smaller-body case. I was cooking starters with the headers on my 429 so I took the delco starter, which had a solenoid on it like a GM, off(which was factory in 70) and replaced it with a smaller body unit and voila!! problem solved.....good luck
ramrod7373
Jun 26, 2013 03:18 PM
Robby Nash
Sep 14, 2012 05:43 AM
Fullcrew7.3
15
Feb 11, 2011 05:41 AM
Good-Deal1023
Sep 30, 2010 10:09 AM
grover
Jan 16, 2009 01:41 PM
