Gauges are installed!!
Old Mar 15, 2009 | 07:05 PM
just another truck's Avatar
just another truck
Originally Posted by maevans
I bet it was killing you today Pat, being it was 60 degrees today. Tomorrow the day.
Oh I hope so.. I have got the itch I'm telling you..
Matt, where did you hook you power to for the gages? Do you have a seperate switch other then the instrument panel lights??
Old Mar 15, 2009 | 07:11 PM
mxracer3276's Avatar
mxracer3276
I followed these instructions on installing the power. I i did not wire in a seperate switch, i wanted to but i kind of got lazy and just wanted to get it done.
Power:
3-Gauge Install Pictures
Illumination:
Old Mar 15, 2009 | 07:18 PM
fxstbchopper's Avatar
fxstbchopper
Looks good Matt..
I almost went with the woodgrain but decided on the color match instead now I know what it would have looked like.
Old Mar 15, 2009 | 08:27 PM
mxdadof2's Avatar
mxdadof2
looks good matt, the wood grain is classy
Old Mar 15, 2009 | 09:09 PM
Gcrop's Avatar
Gcrop
Wood grain looks good and makes me think of going that way to match the current wood grain.
Old Mar 16, 2009 | 07:04 AM
mxracer3276
Yeah i'm happy with how they came out. Thanks again for the comps guys!
Old Mar 16, 2009 | 07:09 AM
just another truck
Thanks Matt, by the way, where did you pull your Pyro from, and your boost?? I am pacing right now waiting for Mr Brown..
Old Mar 16, 2009 | 07:38 AM
mxracer3276
I got my pyro from the driver side up-pipe just above the junction. i only put it here because this was where it said to use because i was using the band style clamp, not the drill and tap. I believe with the drill and tap you do it just below where i drilled mine. Here is a pic:
I got my boost from the AIH. I bought the plug from pure diesel power with the boost fitting tapped into it.
Air Intake Heater AIH Plug for 99.5-2003 Ford 7.3L Powerstroke Diesel
Old Mar 16, 2009 | 07:39 AM
03_PSD's Avatar
03_PSD
Those gauges look killer Matt, nice job!
Old Mar 16, 2009 | 07:42 AM
mxracer3276
Thanks Glenn!
Old Mar 16, 2009 | 08:00 AM
mxracer3276
Hope that helps Pat!
Old Mar 16, 2009 | 08:05 AM
just another truck
Absolutly.. was going to rep you for it.. but was shut down..
Old Mar 16, 2009 | 08:10 AM
  #28
big poppa's Avatar
big poppa
The gauges look great Matt...
Old Mar 16, 2009 | 08:27 AM
  #29
Jason6969's Avatar
Jason6969
Does this come with the auto meter gauge and how accurate is it versus the drill and tap method, Just curious because i'm getting ready to put gauges on mine.
Old Mar 16, 2009 | 08:43 AM
  #30
redfire42's Avatar
redfire42
You can order either one. I don't think there would be a dif in reading since they would only be like 4" apart. I think drilling the up pipe would be alittle easer, because thats what I did.
Gauges look good. Never seen the wood grain on the A post before only on the doors.
