You bet! That is just what you want, go get it. If you search on "Jag XJ IFS" you will find a number of threads inclunig one big one that is titled "jag XJ IFS" with bunches of info. I have some photos in my gallery as do others.
I'm pretty sure with the jag setup the rotors are nowhere near the rims,as they are up next to the diff. like the corvette
True on the rear, but not the front. I believe the bolt pattern is that of a Chevy, but you could have the hubs and rotors redrilled to your Ford pattern.
ifs not irs do you think there are blank rotors that can be drilled for the 51/2 bolt pattern thanx
I did not go that route howvever I suspect that you may be able
to redrill the jag rotors. My only question is if the rotor hub diameter is large enough to get the 5 1/2 bc.
I am not able to get to my truck in the near term. Maybe one of the other guys can check for you.
What I did was to buy new genie style rims that take the original hubcaps. Best buy was Summit Racing. The new rims can be purchased with the 5 x 5 1/2 or the duel bolt patern of 5 x 4 1/2 and 5 x 4 3/4. the jag is 5 x 4 3/4. New rims powder coat primes were about $80 each delivered.
well I just got blessed with a custom cut set of boyd coddington billet wheels 5x51/2 with a 4 inch offset If Icant use these on this ifs swap then i will stay wth my solid axle front suspension you see a dropped axle is say 500 and the disc brake setup is say 450 then i may as well stay with this because i cant get rid of these rims eh
