Best engine for dd/ reliablity?
Old Mar 14, 2009 | 07:23 PM
mattri's Avatar
mattri
If you could swap any motor into your bumpside, what would it be? Leaving out the hassle of the swap itself, and excluding exotic or ultra- unrealistic motors what would you go with?
FE- a stock choice, easy. Lots of power not so great on mileage, harder to find cheap parts.
SB- Huge aftermarket, decent mpg ok power for a dd cheap to build, kind of boring.
Straight Six- dead reliable, easy to build, ok for dd not tons of power or great mpg.
335 series- a little different, pretty good power, not awesome mpg.
385- tons of power, a little wow factor slightly more modern design again, not fantastic mileage.
Something else?
Old Mar 14, 2009 | 08:04 PM
Mikestrucks's Avatar
Mikestrucks
You said DD and reliability.
300 strait six. Will get as good a mileage as any of them other than SB and you can put a fast rear axle ration in there and do just fine.
Assuming 4X2 of course.
You will drive the rest of the truck into the ground with a new 300 six behind a modern 4sp or C6 and good road gears.
Old Mar 14, 2009 | 08:16 PM
wizzard351's Avatar
wizzard351
300 with a 3sp overdrive,hands down. i have never ben able to blow a 300 and god knows ive tryed. there probably the tuffest engine ford biult
Old Mar 14, 2009 | 09:03 PM
justiz00's Avatar
justiz00
3.9 4bt cummins. reliable, good fuel mileage, plenty of torque for a stock replacement motor. Flywheel housing for a ford tranny though would be tough to find, but are around. 6bt 5.9 also, just more torque and power, mileage a little lower.
Old Mar 14, 2009 | 09:07 PM
Redcat Diesel's Avatar
Redcat Diesel
Look for 80's bread vans. A lot of them that came with 300's were repowered with 4bt's. A lot of them are getting scrapped due to rusted out frames.
Old Mar 14, 2009 | 09:39 PM
bmuhlbach's Avatar
bmuhlbach
351w c-6 is my choice
Old Mar 15, 2009 | 01:00 AM
justiz00's Avatar
justiz00
I had a 6bt 5.9 with the flywheels housing out of a bread van. It was a gm pattern with a TH475 and np203 rangebox. I was on the 4x4 kick for a while but that never materialized.
Old Mar 15, 2009 | 09:48 AM
mattri's Avatar
mattri
Thanks for the replies, figured the 4.9 would get a lot of support. In a 2wd wouldn't a T5 be a good choice behind the 300? Good street gearing, bellhousings match, cable clutch so its easy to swap over and you get a decent od.
Old Mar 15, 2009 | 07:36 PM
carcrafter22's Avatar
carcrafter22
For ultimate reliability, best mpg's, and awsome power I say go with a diesel. The cummins 4bt or isuzu 4bd1t/2t's are very easy to swap into these old trucks and can easily be adapted to any ford or chevy trans and only needs one wire hooked up to the motor so the swap is as simple as making motor mounts and radiator hoses basicly.
I for one was getting 32mpgs around town (verified over 3000 miles of driving) in my 67 F100 with an isuzu3.9L diesel and it would out run most vehicles on the road, not exactly a vette killer but still pretty quick. These little diesels were designed to go well over 300,000 miles in 14,000 pound trucks pulling loads and being abused like step children, most of them go way past 300,000 miles even with all the abuse they get just imagine how long they will last in a 4-5,000 pound truck.
Old Mar 16, 2009 | 07:12 AM
71'3604speed's Avatar
71'3604speed
Like everyone else has said, the 300 straight six is an engine that won't die. Put a 3.08 rearend in there and you are set.
Old Mar 16, 2009 | 08:26 AM
Unimog005's Avatar
Unimog005
390.....390.....390....390........390......
Honestly...other than the occasional tune-up, I never have to do anything with my engine....
As for mileage...I get 13-15.......which beats the pants off the new F-250's.....
nstueve
Dec 19, 2012 05:49 PM
nicksex
Dec 3, 2012 08:15 PM
59flatbedford
Feb 20, 2012 10:38 AM
omc124
26
Apr 22, 2011 10:01 PM
saskpwr
Jan 28, 2011 12:43 PM
