6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
deisel in oil
Old Mar 14, 2009 | 05:52 PM
mud_man's Avatar
mud_man
deisel in oil
have two 550 08's and seem to have a qt or two extra oil on dip stick at oil change time last time sent it in and 10 0/0 deisel in oil ford said it came in when it regenerates change oil @ 3000 miles will re check next time at 2500 miles has some boby else notices it
Old Mar 16, 2009 | 10:47 AM
Scout's Avatar
Scout
I just opened the mail - recall on my wife's 2008 F-450. Injector O-rings may be leaking and letting fuel into the crankcase. They inspect and/or replace O-rings and/or injectors and inspect/clean/replace the charge air cooler since it may now be contaminated.
Her truck is a job 3 build - I was hoping there would be less issues with it.
I think the regen excuse is BS. Stay on them.
Old Mar 16, 2009 | 05:36 PM
PSDx3's Avatar
PSDx3
I can't imagine that regen has anything to do with fuel contamination in the oil. Any level of fuel in the oil is contamination, no matter what they say. Their either trying blow it off or hope you go somewhere else. My 08 is also a job 3 and haven't had the problem yet, hope I don't. I test oil every change so I will know at the slightest level of contamination.
Old Mar 17, 2009 | 11:42 AM
Bobby Light's Avatar
Bobby Light
That was fords explanation before the injector failure analysis.
tell them to look up TSB 09B08
Old Mar 26, 2009 | 07:51 PM
mud_man's Avatar
mud_man
will do thanks
Old Mar 29, 2009 | 09:48 AM
gwcon's Avatar
gwcon
Has anybody had the injector recall done yet?
I inquired about it yesterday and my dealer informed me that they have to order the parts for the injector replacement recall from FORD before they can do the work. They said that FORD is performing this replacement work on a case by case basis.
Old Mar 30, 2009 | 11:05 PM
mud_man's Avatar
mud_man
have had oil tested twice and one more I will taks to ford and see what is said
Old Apr 11, 2009 | 10:22 PM
sawtooth's Avatar
sawtooth
Is this a cab off procedure? I've seen some say yes and some say no. I may be getting a little fuel in aswell but not really too excited about having the cab taken off.
Old Apr 12, 2009 | 08:42 PM
sawtooth's Avatar
sawtooth
Still curious is the injector replacement a cab off repair? I've heard it both ways. I checked my oil today 2000 miles after the last change and it doesn't look like i'm making any oil yet so i'm keeping my fingers crossed.
Old Apr 12, 2009 | 09:15 PM
gwcon's Avatar
gwcon
Sawtooth,
Don't know for sure about the cab removal. However, my dealer told me it would be a half day fix. I do not know how long it takes to remove and replace the cab. Sorry I am not much help but I'm trying. I am still waiting for the parts to come in.
Old Apr 13, 2009 | 09:25 AM
AllWhite08's Avatar
AllWhite08
I cant imagine they could remove the cab and replace in a half a day.
Old Apr 13, 2009 | 10:25 AM
UGA33's Avatar
UGA33
If its just injectors, the cab won't have to come off. If lets say the HPFP had to be replaced, then yes it would have to come off. If the tech is experienced with it, the cab can be off in 1.5-2 hrs.
Old Apr 13, 2009 | 06:27 PM
mud_man's Avatar
mud_man
I will change oil this week and have it checked and call dealer
Old Apr 13, 2009 | 06:38 PM
caprang's Avatar
caprang
UGA33 hit it dead on. For injectors only the cab does not have to come off.
Old Apr 13, 2009 | 06:45 PM
sawtooth's Avatar
sawtooth
that sounds good to me. I just turned 2000 miles and i can't see any extra oil yet. I will take her to 5K before changing it. By then i should notice an increase in oil if the injectors are in fact leaking.
