holley 4160 mixture screws
Old Mar 17, 2009 | 08:42 PM
LxMan1's Avatar
LxMan1
It is only 80% VE at best.
The screw will be on the very bottom. You should be able to see the tip of it on the passenger side sticking up out of the base plate touching the secondary linkage under the diaphram rod, I believe.
Old Mar 17, 2009 | 09:10 PM
2classics's Avatar
2classics
yeah, I saw it, just never thought of it.
.80 you think? I guessed from different books I've read.
Old Mar 17, 2009 | 11:06 PM
Sooper-Doodie's Avatar
Sooper-Doodie
Originally Posted by 2classics
Good calculator, but I think you read the 100% VE.
I was mistaken on the cid. My new engine is .040 to get 409cid.
edited. disregard.
Old Mar 23, 2009 | 07:57 PM
2classics's Avatar
2classics
Took the carb off, made sure the secondaries closed all the way,put it back on and same thing. Throw a rag over them, raises rpm slightly,then dogs down. Checked to make sure the vacuum wasn't pulling on them. I'm at a loss.
Old Mar 25, 2009 | 12:39 PM
LxMan1's Avatar
LxMan1
Does it run ok? What other problems besides it won't die by moving the mixture screws?
I honestly can't remember if the one I had would lean out that much or not.
HarlanThomas
15
Apr 9, 2010 02:10 PM
DVM04
Feb 24, 2007 08:33 PM
Arrow201
Aug 9, 2006 01:00 PM
ford390gashog
Sep 14, 2004 11:28 AM
