quick question????
Old Mar 13, 2009 | 10:42 AM
clowe's Avatar
clowe
quick question????
this morning my o/d light began to flash and I knew it was something with the transmission. Just for giggles I turned the motor off to see if it would reset and stop. it did but it felt like it took longer to change into o/d. My CEL did not come on and was wondering if there would be a code stored somewhere on this ploblem?
Old Mar 13, 2009 | 10:45 AM
99Xplr's Avatar
99Xplr
What year/engine is your Explorer?
If you go over to AutoZone, they can plug in a scan tool and print out the report for free.
Old Mar 13, 2009 | 11:59 AM
marragtop's Avatar
marragtop
Normally when the OD light is flashing, the trans goes into 'limp' mode which causes it to shift harder which is not good for the trans. You can try pulling the codes, but you can't always get trans codes from pulling from the PCM.
Old Mar 13, 2009 | 04:20 PM
clowe's Avatar
clowe
it is a 2001 with the 4.0
