air filter
Old Mar 13, 2009 | 10:59 AM
superduty4x4's Avatar
superduty4x4
Originally Posted by jasonch
also, this hose wont collapse on me? is there no way to use the factory hose going there and reduce it or anything?
What hose are you talking about? As for the sensor, zip-tie it out of the way and be done with it.
Old Mar 13, 2009 | 11:32 AM
jasonch's Avatar
jasonch
ok i got you, and the hose you guys were talking about just connects the new filter to the factory intake hose, right?
Old Mar 13, 2009 | 11:41 AM
superduty4x4
No hose, either 4" exhaust tubing or a 3" ABS or PVC pipe coupler. Exhaust tubing is better- thinner walled, less flow restriction.
Old Mar 13, 2009 | 11:57 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Depending on your truck, you may need a straight piece of pipe, or you may need a 45degree elbow. A select few have been able to clamp the filter directly to the hose off the intake box. Also, depending on your specific trucks, you may need to alter the battery box. I removed my battery/air box and used a sawzall to cut it to make room for the filter. Some just remove the airbox. My 97 had the air box removed. The 02 needed some modification.
Old Mar 13, 2009 | 12:00 PM
F250_'s Avatar
F250_
He's got a '99, but I can't tell if it's the early bird or not.
Old Mar 13, 2009 | 12:08 PM
CampSpringsJohn
Hey Jasonch, F250_ is the guy that has the filter covers on here. If you look around on here, you should be able to find him,,
Old Mar 13, 2009 | 12:13 PM
patrickke's Avatar
patrickke
some people even build boxes to go around there filters and seal them at the hood...but thats if you wanna get creative
Old Mar 13, 2009 | 12:34 PM
jasonch's Avatar
jasonch
mine is a late 99. it looks to me like i will need a 45, just ordered 2 filters. gonna get the covers after i get everything like i want it. they have got some metal exhaust hose they say is flexable, but it doesnt feel like it. i will only need about a 4 inch piece, so i dont see it flexing much, think i will just do away with my box all together. what else is an option for metal here. i want my factory intake hose to go over it, and the nipple on the end of the filter to go over it too. 4 inch ID right?
Old Mar 13, 2009 | 01:08 PM
superduty4x4
Late 99 won't need a 45* piece, just a straight piece about 4" long.
Old Mar 13, 2009 | 01:14 PM
megawatt00's Avatar
megawatt00
Like this:
This was before I got the cover from Pete.
Old Mar 13, 2009 | 01:29 PM
patrickke's Avatar
patrickke
i think thats the best one I have seen
Old Mar 13, 2009 | 01:35 PM
CampSpringsJohn
Agreed, but it won't work without the FTE sticker.
Old Mar 13, 2009 | 01:37 PM
  #28
patrickke's Avatar
patrickke
I wish I had a fte sticker
  #29
megawatt00's Avatar
megawatt00
Thanks. It took a while to make. Some day when stuff gets straighted out here I may make a few more.
PM me your name and addess and I'll get you a sticker. These are not the official ones. I had these made up last year.
Old Mar 13, 2009 | 02:05 PM
  #30
jasonch's Avatar
jasonch
i want a sticker too! LOL. My hose going to my airbox will be to short, and it looks like it will hit the battery if it goes straight, so i need to find a 45 or at least a 30 degree bend. the exhaust hose will not bend, espesially if it is only 4 inches long, now my 02 has a different set up on it, all i need is something hard for the intake hose and filter to clamp to and it will be set.
