Sponsored by: Kumho
Suggestions and Advice?
Old Mar 13, 2009 | 07:15 AM
FordF350Baby's Avatar
FordF350Baby
I am doing the shackle reversal kit install today after class on my 1995 F350, but wanted to see if I could get some of insight before tackling the project. Firstly, I wanted to hear what you guys suggested for drill bits for drilling holes through the frame. There's going to be quite a bit of drilling, and I could imagine it getting expensive. Secondly, I plan to replace the front u bolts from the front leaf springs, seeing they probably are going to need to be replaced for removal. My question is, will it be safe if I just sawed right into them with a angle grinder, or is this pressure there under be dangerous to just try and cut directly into them. Thank you.!
