Ok guys any off you change your glow plugs out. So what is the first symptoms that there not working properly. GPR Glow plug relay what issues here. When its not working what are the symptoms. Fuel injectors so if they go bad what are the symptoms. Sorry for all the questions guys. Just trying to learn.
The first thread that I posted for you will explain how to test the GPR also. Basically you have two large terminals 1 is "hot" (line) and one is "hot when on" load" Test the voltage to see if you have 12 volts going to the line side, turn the key to the on position and see if you have 12 volts going to the load side. Take your meter and put a lead on each of the large posts when it is energized the closer to zero volts you have the better the condition of the relay.
Are you getting an SES light? Have you had the codes read?
Quite a few have done injectors and will guide you through the process. Let's start with the basics first, You may just have a loose UVCH.
What are the symptoms and problems that you are having?
