fuel filter drain valve doesn't train
Old Mar 12, 2009 | 04:21 PM
ngng's Avatar
ngng
I encountered this when I was doing my fuel filter change. I ended up just sucking the fuel out, but would like to fix this
Old Mar 12, 2009 | 04:26 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
next time open the valve leave the filter cup on tight ,and have somone turn the key till the pump comes on, that would clear the drain pipe instantly...
good luck....
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here is how to take the valve apart. Don't forget to get new o-rings. The site that this artical is on is where you can get new o-ring kit for this.
click here
Old Mar 12, 2009 | 04:38 PM
ngng's Avatar
ngng
good luck....
good tip!
what's the service interval on a fuel filter? I've noticed lots of pumps here contain biodisel blends, and I know biodiesel is a solvent
Old Mar 12, 2009 | 04:51 PM
61 uni's Avatar
61 uni
Filter every 15k.
Old Mar 12, 2009 | 05:08 PM
ngng's Avatar
ngng
Originally Posted by 61 uni
Filter every 15k.
hell, I don't drive my truck that much...I'd do it evey year then!
any ways to check the filter to see if it needs replacement?
Old Mar 12, 2009 | 05:17 PM
ron's power stroke's Avatar
ron's power stroke
if you dont know how long its been in there..change it now..write the date and miles on a piece of tape and stick it in the top corner of your windshield..
i change mine twice a year..spring and fall...miles dont matter..
Old Mar 12, 2009 | 05:50 PM
Ponyboychris's Avatar
Ponyboychris
That's my procedure. I just don't drive it enough to get let the miles dictate my changes.
Old Mar 13, 2009 | 02:22 AM
kupaa's Avatar
kupaa
just stick a 1/4 vaccume hose on the end of the drain tube and blew it back with air.
Old Mar 13, 2009 | 02:46 AM
orng1's Avatar
orng1
Haven't had an issue with mine, it's always been smooth open and close. You guys must be getting into some messy stuff.
Old Mar 13, 2009 | 07:55 AM
Ponyboychris
Or the tube has some gunk it it to block it from draining. I've read that insects like to climb up there and make nests.
