2004 trouble starting
Old Mar 12, 2009 | 10:50 PM
marton2's Avatar
marton2
HI I HAVE TO TURN THE KEY 5 TIMES TO START MY TRUCK REPLACED FUEL FILTER AND STILL THE SAME ANY IDEA DO YOU THINK FUEL FUMP OR CRANK SENSOR THANK YOU
Old Mar 13, 2009 | 12:15 AM
rob188's Avatar
rob188
what do you mean? do you turn the key on and off 5 times then try to crank?
Old Mar 13, 2009 | 12:29 AM
deisele75's Avatar
deisele75
I bet it is throwing some codes. You should hook it up to a computer to find out.
Old Mar 13, 2009 | 12:35 AM
rob188's Avatar
rob188
i agree could be low fuel pressure
Old Mar 13, 2009 | 04:39 PM
Greg B's Avatar
Greg B
I'd see what codes it has stored. Sounds fuel pump related, though.
Greg B
Old Mar 14, 2009 | 02:03 PM
rob188's Avatar
rob188
Greg B
i would agree and say fuel pump as well, atleast as a starting point
Old Mar 14, 2009 | 06:59 PM
marton2's Avatar
marton2
Hi i replaced the fuel pump and still doing the same i have to turn the ignition key 5 tmes i guess is when the fuel build some pressure or some thing what about the crank sensor do you think it has to do something whit it
Old Mar 15, 2009 | 11:41 AM
rob188's Avatar
rob188
crank sensor could be another problem yes, maybe try that and see what happens.
Old Mar 15, 2009 | 11:11 PM
DRM2004's Avatar
DRM2004
Have you scanned for codes?
