anyone hear a loud ping noise coming from engine just after shutting down after a drive? it usually does it a couple times, but today did it like 5-6 times over a 10 minute period while i was fueling up. i assume it is something cooling down, but i can't figure out where it is coming from. hoping it is not a problem.
i do have the 6637 and 3.5" DP, but no other power mods. no pyro gauge... think i need one?
any ideas what this noise may be or if i should bother worrying about it?
If it was the turbo, it would make a humming sound as it wound down, the way you described it sounds like its a sharper sound, like a hammer hitting a piece of metal?
Give us a better description!
Sounds like he is hearing exhaust cool down of the metal.
I figured all trucks do it.
The turbo shouldn't make and ping sounds at all. Well, unless its bad. but it still shouldn't be a ping. Would be a Rattle?
i should clarify- the noise happens about a minute after i turn the truck off so the turbo and everything is still. and it is like a small hammer hitting metal. pting!
