losing water
Old Mar 12, 2009 | 10:31 PM
f250_kinda_girl's Avatar
f250_kinda_girl
losing water
hey, looking forward to maybe getting some help.
87 with a 302 injected.
I lose water but can't find a leak. Have changed out a few hoses and the radiator cap. It even loses water when parked and not running.
Any suggestions?
Thanks
Old Mar 12, 2009 | 10:44 PM
Old93junk's Avatar
Old93junk
Possible head gasket, have you checked for water in the oil?.. Do you have lots of steam from the exhaust that takes forever to go away?
Old Mar 12, 2009 | 10:56 PM
phoneman91's Avatar
phoneman91
Look for dried antifreeze between the radiator core and the radiator tanks. A likely source of coolant loss--especially if the radiator is original.If this is the source--the rubber O rings that seal the tanks to the core are leaking.And usually only does this when the engine is running and the cooling system is pressurized. Pressurizing the system with the engine not running ,wouldnt be a bad idea neither,as a test.
It can seem that the coolant is disappearing when the engine isnt running because the coolant can be lost during operation-and not noticed until the system cools down and the overflow reservoir is lower the next morning.
When changing the oil-place the used oil in a clear container and check for antifreeze at the bottom of the container the next day.
Old Mar 12, 2009 | 11:09 PM
f250_kinda_girl
no water in the oil, but have not changed it since this issue started. No stream in exhaust.
Old Mar 12, 2009 | 11:12 PM
f250_kinda_girl
I guess I should have been more clear, there is a puddle of water on the ground after sitting. That's what I meant when I said it loses water when not running.
Old Mar 12, 2009 | 11:17 PM
Old93junk's Avatar
Old93junk
Then Phoneman probably nailed it, tank seals give out on these radiators. you can try to have the tanks re-crimped or look for a new radiator.
Old Mar 12, 2009 | 11:26 PM
phoneman91's Avatar
phoneman91
How hot is it there in Cali this time of year?? Does the truck have air conditioning?? If so-are you using it when this trouble occurs??
ottawaguy's Avatar
ottawaguy
First off.....Welcome to Ford Truck Enthusiasts
I would park it hot and get a good light and try to find the leak. If it appears to be coming from the rad area...then phoneman91 has likely given you the answer. Check bottom rad hose?..sometimes it'll leak and run down the underside of the hose and drip under the front of the engine.
I just had to replace my rad as well when a crimp/gasket gave out...or at least that is where it leaked from. I could find nothing visibly wrong either.
If you have straight water in your engine, it might be harder to tell.
Let us know what you find.
worth mentioning for sure!
Old Mar 13, 2009 | 02:03 AM
f250_kinda_girl
It's been cold, 30's mostly, rain and snow off and on. Has air, but never used.
Old Mar 13, 2009 | 02:05 AM
f250_kinda_girl
I replaced the bottom hose.
Old Mar 13, 2009 | 05:40 AM
phoneman91's Avatar
phoneman91
Is this pure water?? Not antifreeze?? Clear water?? Where under the truck does the water seem to be coming from?? In front of the front wheels?? Behind the front wheels?? On passenger or drivers side??
Is the resevoir tank at normal level or empty in the morning??
Old Mar 13, 2009 | 05:06 PM
f250_kinda_girl
It's antifreeze/water. The water on the ground is about in the middle between the front tires. Like almost straight down from the water pump. But there is never any visable leak. And sometimes the the resevoir is empty and some times it's not.
Old Mar 13, 2009 | 05:28 PM
ottawaguy's Avatar
ottawaguy
Water pumps have a weeper hole which will leak when the pump goes bad. Not sure if it only leaks when running or if it will leak when manually pressurized, but If it does appear to be your water/coolant in the spot you mentioned, I would check the thermostat housing for leaks or sign of leaks( crud buildup...color will depend on amount of coolant in water), but I'm suspecting that your pump is done.
Find the hole..make sure it is dry and then run your truck and see if it leaks from that hole or if the hole is wet after you shut it down. Not sure why it would only leak intermittently.
Let us know...best of luck!
Old Mar 13, 2009 | 06:05 PM
quicklook2's Avatar
quicklook2
go to radiator shop and have the system pressure checked.
they will usually do it for free and then you will know where leak is instead of guessing and replacing parts.
Old Mar 17, 2009 | 11:01 PM
f250_kinda_girl
I took a picture so you could get a better idea. This was after it was parked the evening before and I left in mid morning.
