Original motor
Old Mar 12, 2009 | 08:55 PM
rob8210's Avatar
rob8210
Original motor
Is there any way of determining if the motor in my truck is the original? I have a 1979 F250 4x4
Old Mar 12, 2009 | 10:22 PM
Holiver31's Avatar
Holiver31
well you could check your vin and see if its the same model of engine,,i dont know if you can tell if its the original one
Old Mar 12, 2009 | 10:27 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The three original engine choices for 1977/79 4WD's were the 300 I-6, 351M 2V and 400 2V.
The engine code is the 4th digit of the VIN:
B = 300-I-6 / H = 351M / S = 400.
Old Mar 13, 2009 | 12:34 PM
rob8210's Avatar
rob8210
Thanks for the quick responses. I did determine that it is the original equipment I am wondering if there is ant way to determine if the motor is the exact one that came in it originally. It is a 351m , engine code 'H'
Old Mar 13, 2009 | 01:16 PM
NumberDummy
I am wondering if there is any way to determine if the motor is the exact one that came in it originally.
It is a 351M, engine code 'H'
There no way to know, because there are no serial numbers or VIN's on Ford mechanical parts.
Numbers matching is a GM thing.
Old Mar 14, 2009 | 12:36 PM
lsr490's Avatar
lsr490
rob8210
The first thing you have to do is figure out the date your truck was made. The best way to do this is on the passenger side of the frame, approximately in the area between seat bracket bolts of the cab, and the warranty sticker of the drives door jamb. You will find the part number of your frame and a date of manufacture. Now that you have that you can compare the date of the assemblies of the block. The date code of the heads is under the valve cover, on the intake manifold in front of the carb, and the block behind the starter. Your codes will be four digits and start with an 8 or 9 depending on when your frame was made. Early in the module year will be an 8 late in the MY will be a 9. The second digit will be letter A-M corresponding to a month A= January M=December The letter “I” will never be used. The last two digits will be a number between 01 and 31 that corresponds to the day of the month. The rule of thumb is that the engine should have around the same date as your frame with in a month, but never newer than the assembly date on the door jamb. The chances of someone replacing your engine with the correct date code are very slim.
I hope this helps you out, if not don’t be afraid to ask more clarifying questions.
ND I do want to get into a peeing contest but, I believe it was a Federal requirement by the mid ‘70s to have a partial VIN somewhere on the drive train. I believe I read some where it was on the tail shaft of the tranny.
LSR490
Old Mar 14, 2009 | 02:40 PM
NumberDummy
Originally Posted by lsr490
rob8210
LSR490
The stamping of VIN's on mechanical and myriad body parts did not begin until the late 1980's.
Engine date codes are useless for finding out when the engine was originally installed, because engines are made by the 10's of 1000's at several different engine plants, then shipped to the assembly plants.
The dated block could have been installed months after it was assembled. Same thing goes for the heads, intake manifolds...you name it.
Ford frame ID numbers and dates are (usually) stamped on the passenger side outer frame rail, about one foot to the rear from the front frame horn.
Frames are made by the 10's of 1000's by an outside supplier (American Frame & Axle is one of the company's Ford used), so just because there's a date code, the frame could have been installed weeks or months later after it was made.
You can pin down the month the truck was assembled by looking for the PRODUCTION DATE that is listed on the white Certification Label.
btw: There are no actual Ford part numbers stamped, cast or by any other method marked on parts after 1956.
The only numbers on parts after 1956 are ID numbers. Most parts are not marked at all.
Did you notice my signature? I didn't start doing this jazz yesterday.
I was a Ford partsman for 35 years, and have been a car/truck collector for over 50 years.
Old Mar 14, 2009 | 03:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
I agree with Numberdummy, no way to tell for sure.
But there are hints....
Look for the emissions sticker on the valve cover. If it's still got one.
If the year on the sticker matches the year of the truck, then it's good odds that you have the original valve cover at least.
Does not mean that the engine hasn't been rebuilt, or swapped for a short block however. the odds are that it has at least been gone through once for a 30+ year old truck.
Old Mar 14, 2009 | 07:49 PM
lsr490's Avatar
lsr490
I am just over whelmed with the open communication that we have.
There is only one person on here that knows everything, right dummy number?
In your reply you wrong in so many ways there not even worth countering.
There is a reason they left you behind the counter for thirty-five years, GURU.
Of the 15 Ford vehicles and over 25 engines I have owned, the funny thing is they all still had the factor valve cover and emission sticker on them, great source.
Old Mar 14, 2009 | 08:06 PM
myv-879's Avatar
myv-879
I believe that Ford Australia did it abit different. We have matching vin and engine Numbers when new, Maybe this is a bit off topic but a peice of trivia for all you sepos! (lol)
Old Mar 14, 2009 | 08:11 PM
Bgasrickshaw's Avatar
Bgasrickshaw
O.K. I'm really off subject now, but what is a "sepo"?
Old Mar 15, 2009 | 01:45 AM
NumberDummy
Where exactly was I wrong smart azz?
There are no VIN's or serial numbers on emission stickers.
All the emissions sticker will tell you is the year, but the OP wanted to know if he has the EXACT same original engine that came with the vehicle when it was brand new.
How can anyone tell by the emissions sticker if the engine is the original to the vehicle? They cannot.
There are no VIN's on mechanical parts till the late 1980's.
Old Mar 15, 2009 | 05:31 AM
myv-879's Avatar
myv-879
Its Aussie rhyming slang for people who recide in or are from the North American country of The U.S.A " Septic Tank = Yank " Thats what the rest of the world calls ya all. No offense intended but if you are offended blame the English, I think we borrowed it off them.
Old Mar 15, 2009 | 06:49 AM
rob8210's Avatar
rob8210
Thanks for all the info, Nd was right on I was wondering if there is some way to determine if I had the engine that was installed at the factory. Now I know better than to ask that again. By the way Nd I think you do an amazing job with part numbers and research on where to find hard to find parts. Thanks so much.
68fordman
Dec 20, 2012 02:24 PM
mike4x4
27
Jun 17, 2009 05:05 PM
62 PUP
May 24, 2003 04:49 PM
JWJ37
Jan 20, 2003 07:53 PM
JiminAussie
Sep 8, 2002 10:42 AM
