My 10 year 1995 Ford F250HD project bought from a neighbor it was filled with tree needles from sitting under a tree for years , it was a theft recovery . then sat around my place for about 10 years with no glass and started up pretty much every time to haul stuff around the property then I found a donor truck and put the white cab on the 1995 , it has about 70,000 miles 300 inline six and a c6 auto with 4.56 gears . the check engine light keeps coming on so I am going to have to change the in cab wiring harness and the windshield wipers don't work .
before pic
After pic
It was real easy , just undo the master cylinder from the booster dont take off the lines unhook all the electrical , steering shaft and 6 bolts holding the cab on and some other odds and ends and it comes right off . I just put some straps through the cab and under it .
The code that came up has something to do with it not being in park during testing , the white cab was an F150 6 cylinder 5 speed . all the dents and dings look like someone took an ax to it while it was stolen .
