Changing rear differential
Old Mar 13, 2009 | 05:54 AM
150ford's Avatar
150ford
Ok guys have any off you did this. I was going to change mine soon but was just curious the proper way to do it.If I remove the differential cover is there anything I should look for when changing the oil. Thanks everyone for any help
Old Mar 13, 2009 | 06:14 AM
megawatt00's Avatar
megawatt00
Here are a couple of links that you'll find useful:
Welcome to guzzle's Rear Differential Maintenance Web Page
Roadside Help Network - Guides, Maintenance & Mods
Old Mar 13, 2009 | 07:22 AM
03_PSD's Avatar
03_PSD
i used guzzle's and went very smooth
Old Mar 13, 2009 | 07:32 AM
jdecker88's Avatar
jdecker88
I am going by Guzzles method when I put my Schaeffers in my truck.
Old Mar 13, 2009 | 09:05 AM
brian42's Avatar
brian42
Veteran: Navy
I used Guzzle's writeup and it went fine. Definitely let the gasket material skin up for 1/2 hour before you put the cover back on and wait as long as you can to fill the pumpkin so that the gasket has time to set.
I would also re-check the torque on the bolts a little ways down the road. I changed to the '08 rear cover and developed some weepage about a month later. I re-torqued the bolts and the weepage stopped. Only a couple of drops hit the ground but the small stain on the diff cover got noticeably larger over a few day span until I crawled under there with my torque wrench and put an end to the fluid's escape.
BTW I used Mobil 1 synthetic gear oil and didn't have to add any friction modifier for my LS.
