I tried to order a set of rocker panels from Mid fifty for my 55 and was told that they were on back order until May. So I ordered a set from Dennis Carpenter. The ones that arrived were not actually made by them but rather by Blue Oval.
There is something odd with these that I can not figure out. If you look at the picture, about 4 inches before the "A" pillar attaches there is an indentation. At first I thought that the this was the location for the "A" pillar to attach, but it is too far back. Any Idea why they did this? and what should I do?
Mid Fiftys catalog shows that as for the 56, but also says that the standard W/O indentation will fit 53-56. The indentation is for reinforcement added to the 56 model.
You might want to call carpenter to verify this with them.
brian...
I called Dennis Carpenter and they are very nice people. They verified that this is the 53-55 rocker panel, the 56 does not have the the little step down down at the front edge. They have no idea what the indent is for either but said that all the 53-53 panels they have have it.
That is the rocker for a 56, the 56 has an extended triangle bracket where the 53-55 doesn't. The picture of the one you show is the same ones I bought from Midfifty. The triangle bracket for the 56 goes to the bottom of the rocker on the 56 and only down to the floor on the 53-55. If you go to Midfifty's web site on page 97 you should get the information you are looking for.
John
Does the triangle bracket on the 56 go outside of the rocker? (closer to the door as appose to inside closer to the frame)
Yes that triangle bracket sets against the door post and the rocker behind it, that is why the indentation is there. The bracket will fill the rest of the indentation. I welded mine in and filled with body filler to clean it up.
Well at least the mystery is solved. Thanks. Now how do i get a set of 53-55 rockers with a back order at Mid Fifty
You can use what you have and either buy the brackets or add in another layer that you could form in a vise plug weld them to the rockers you have now, just a thought or wait until Midfifty or another supplier gets you the 53-55"s
I may give a go at fabricating my own. It is just a piece that I will see every time I get in the truck so if its messed up it will eat at me.
Tx, if the rocker panel you are replacing has a good section to it as I'm sure it has, you could use a piece of it to lay over the section of the new rocker,it's already formed. Drill some holes in it and plug weld it to the new rocker and a few stitch welds on the edges and a bit of body filler and you should have it covered.
