Aerostar Ford Aerostar
source for 93 clutch line?
Old Apr 7, 2009 | 04:46 PM
jdelliott's Avatar
jdelliott
I did finally find one, at a junkyard about 50 miles away from me. Hated having to prepay for it, so no matter what I did, it was mine, even if it got screwed up getting it out. Cost me $50, though. I am wondering, are the fittings on each end something that is a normal hydraulic fitting, or are they Ford-specific? if it is Ford specific, is it a current fitting on ANY vehicle. In other words, can I buy (say) a Mustang clutch line, cut the line off, and put new brake line or something on the new fittings, to reach where I need it to, as has been suggested? Just wanting to find out in case I ever run into this problem again, as I have been told that the line freezing in the tranny side and refusing to come out is a common issue. Thanks, John
Old Apr 7, 2009 | 05:07 PM
Rulebreaker's Avatar
Rulebreaker
Usually the master end is held in with a steel pin and the other end is that quick connect never unconnect thing. I believe it's automotive only crap. Only way around this junk is to buy wilwood or some other aftermarket stuff and run a brake line. Both my 75 and 94 Ford's have the wilwood stuff. Much easier to work with. RB
Old Apr 7, 2009 | 05:43 PM
jdelliott's Avatar
jdelliott
can you elaborate on Wilwood? is that after-market clutch parts with a different design or something? a link, etc would be helpfl.
Old Apr 7, 2009 | 08:34 PM
xlt4wd90's Avatar
xlt4wd90
Wilwood makes aftermarket brakes, mostly heavy duty racing parts. Hydraulic clutch lines are essentially brake lines, so a lot of brake parts can be used.
Old Apr 7, 2009 | 09:39 PM
Rulebreaker
Paid 4 and Love it
25
May 29, 2017 01:08 PM
Vaunripped
Aug 15, 2016 10:04 PM
Blackdog 15
1978 - 1996 Big Bronco
Dec 23, 2014 07:02 PM
1990fordf-250
Dec 21, 2014 05:41 PM
Ol Rudy
15
Jan 7, 2005 08:11 AM
